DFRobot Ambient Light Sensor SKU: DFR0026
Contents
1 Introduction
2 Specification
3 Application
4 PinOut
5 Tutorial
5.1 Connection Diagram
5.2 Sample Code
5.3 Result
6 FAQ
Introduction
Here comes DFRobot's new Analog Ambient Light Sensor. Brand new design and much more
convenient to use.This module help you to detect the light density and reflect the analog voltage
signal back to Arduino controller. You can set the threshold of voltage level to trig other unit on
Arduino project.
Specification
Supply Voltage: 3.3V to 5V
Illumination range : 1 Lux to 6000 Lux
Responsive time : 15us
Interface: Analog
Application
Automatic screen brightness control
PinOut
Color
GREEN
RED
BLACK
Pin
S
VCC
GND
Tutorial
Connection Diagram
Arduino
Sensor
A0
GREEN
5V
RED
GND
GRAY
Sample Code
void setup()
Serial.begin(9600); // open serial port, set the baud rate to 9600 bps
void loop()
int val;
val=analogRead(0);
//connect grayscale sensor to Analog 0
Serial.println(val,DEC);//print the value to serial
delay(100);
Result
Open the serial port monitor, set the baud rate according to the program for 9600.The light intensity
around the sensor is different, the received data is also different.The more light, the bigger the data.
FAQ
Q1. Some general Arduino Problems/ FAQ/ Tips, very good to know.
A1. Click the topic link on DFRobot Forum.
Q2. The unit of the output from these sensors is? How can I convert it to LUX?
A2. Well, it is only a simple analog sensor that could show you the relationship of the light
intensity (within its detect range) and voltage (0-5V). If you want to transfer the voltage to unit
in LUX, then well, it requires that you have a commercial Light Intensity Meter like this that
can display LUX info, then you can match the readings to the sensor's analog reading, then
you could a map to describe the relationship of voltage and ambient light density.
For any question/advice/cool idea to share, please visit DFRobot Forum.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0026”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+26.425281+3.43520
- 国内价格 香港价格
- 1+22.911581+2.97843
