DFR0021-R
DFR0021-R
    DFROBOT
    GRAVITY:DIGITALREDLEDLIGHTMO
DFR0021-R 数据手册
  Gravity:Digital RED LED Light Module SKU:DFR0021‐R    INTRODUCTION This red LED light module has a shiny white color. It is ideal for Arduino starter. This module can be easy to be plugged on IO/Sensor expansion shield.  NOTE: This LED is wired to light up when the Signal pin is set to low. The reason for this is to prevent the  LED from demanding too much current from the microcontroller and damaging the I/O.     If you wish to make this LED light up with a logic high, you can switch the Signal wire (Green) with the  GND wire (Black) and the Voltage wire (Red) to the Signal wire's original spot.     SPECIFICATION     Type: Digital  LED light module pin definition : (1) control terminal (2) power supply (3) ground  SHIPPING LIST   Sensor x1  Digital Sensor Cable  (SKU:FIT0011)  x1                                              Powered By DFRobot © 2008-2017
DFR0021-R 价格&库存
很抱歉,暂时无法提供与“DFR0021-R”相匹配的价格&库存,您可以联系我们找货
DFR0021-R
  • 1+6.865471+0.89270
库存:2
