Digital magnetic sensor SKU: DFR0033
Contents
1 Introduction
2 Specification
3 Connection Diagram
4 Sample Code
Introduction
what's the best way to detect the magnet? Use anther magnet. But it's not sensitive enough. You
have to feel it by youself.Right.This magnetic sensor knows whether there is a magnetic object
nearby or not. And it correctly tells you through ditigal output.See below picture for a quick demo!
Specification
Supply Voltage: 3.3V to 5V
Indicator LED on board
Interface: Digital
Connection Diagram
Sample Code
int ledPin = 13;
// choose the pin for the LED
int inputPin = 2;
// choose the input pin
int val = 0;
// variable for reading the pin status
void setup() {
pinMode(ledPin, OUTPUT);
// declare LED as output
pinMode(inputPin, INPUT);
// declare pushbutton as input
void loop(){
val = digitalRead(inputPin);
// read input value
if (val == HIGH) {
// check if the input is HIGH
digitalWrite(ledPin, LOW);
// turn LED OFF
} else {
digitalWrite(ledPin, HIGH); // turn LED ON
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0033”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+25.646811+3.30865
