Shiftout Module (SKU:DFR0072)
Contents
1 Introduction
2 Pin out
2.1 Connection Details
3 Code
Introduction
At sometime or another you may run out of pins on your Arduino board and need to extend it with
shift registers. With this shift out module which is based on 74HC595. The datasheet refers to the
74HC595 as an "8-bit serial-in, serial or parallel-out shift register with output latches; 3-state." In
other words, you can use it to control 8 outputs at a time while only taking up a few pins on your
microcontroller. You can link multiple registers together to extend your output even more. It can also
be applies to 51, AVR, PIC and other microcontroller.
Note:This module can be multipled linked,but too much modules linked may affect the
working efficiency.Twenty may be better
Pin out
Shiftout Module
Connection Details
Input:
D3 connect to Arduino Digital 3
D8 connect to Arduino Digital 8
D9 connect to Arduino Digital 9
VCC connect to Arduino 5V
GND connect to Arduino GND
Output:
D3 connect to the modules' input D3
D8 connect to the modules' input D8
D9 connect to the modules' input D9
VCC connect to the modules' VCC
GND connect to the modules' GND
Code
//Pin connected to latch pin (ST_CP) of 74HC595
const int latchPin = 8;
//Pin connected to clock pin (SH_CP) of 74HC595
const int clockPin = 3;
////Pin connected to Data in (DS) of 74HC595
const int dataPin = 9;
byte Tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
void setup() {
//set pins to output because they are addressed in the main loop
pinMode(latchPin, OUTPUT);
pinMode(dataPin, OUTPUT);
pinMode(clockPin, OUTPUT);
Serial.begin(9600);
Serial.println("reset");
void loop() {
if (Serial.available() > 0) {
// ASCII '0' through '9' characters are
// represented by the values 48 through 57.
// so if the user types a number from 0 through 9 in ASCII,
// you can subtract 48 to get the actual value:
int bitToSet = Serial.read() - 48;
// write to the shift register with the correct bit set high:
digitalWrite(latchPin, LOW);
// shift the bits out:
shiftOut(dataPin, clockPin, MSBFIRST, Tab[bitToSet]);
// turn on the output so the LEDs can light up:
digitalWrite(latchPin, HIGH);
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0072”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+36.898981+4.79789
- 国内价格 香港价格
- 1+44.147581+5.74040
- 3+39.020203+5.07370
