18B20 Temperature Sensor V2 SKU: DFR0024
From Robot Wiki
Contents
1 Introduction
2 Specification
3 Connection Diagram
4 Sample Code
Introduction
DS18B20 is a digital temperature sensor which is from DALLAS U.S. It can be used to quantify
the environmental temperature testing.
The temperature range -55 ~ +125 , the inherent temperature resolution of 0.5 , support
multi-point networking mesh. Three DS18B20 can deloyed on three lines, to achieve multi-point
temperature measurement. It has a 9-12 bit serial output.
Specification
Supply Voltage: 3.3V to 5V
Temperature range :‐55 °C ~ +125 °C
Interface: Digital
Connection Diagram
Sample Code
#include
int DS18S20_Pin = 2; //DS18S20 Signal pin on digital 2
//Temperature chip i/o
OneWire ds(DS18S20_Pin);
void setup(void) {
Serial.begin(9600);
void loop(void) {
// on digital pin 2
float temperature = getTemp();
Serial.println(temperature);
delay(100); //just here to slow down the output so it is easier to read
float getTemp(){
//returns the temperature from one DS18S20 in DEG Celsius
byte data[12];
byte addr[8];
if ( !ds.search(addr)) {
//no more sensors on chain, reset search
ds.reset_search();
return -1000;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.println("CRC is not valid!");
return -1000;
if ( addr[0] != 0x10 && addr[0] != 0x28) {
Serial.print("Device is not recognized");
return -1000;
ds.reset();
ds.select(addr);
ds.write(0x44,1); // start conversion, with parasite power on at the end
byte present = ds.reset();
ds.select(addr);
ds.write(0xBE); // Read Scratchpad
for (int i = 0; i < 9; i++) { // we need 9 bytes
data[i] = ds.read();
ds.reset_search();
byte MSB = data[1];
byte LSB = data[0];
float tempRead = ((MSB
很抱歉,暂时无法提供与“DFR0024”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+51.817671+6.71220
