LPG Gas Sensor(MQ6) (SKU:SEN0131)
Contents
1 Introduction
1.1 Specification
2 Pin Definition
3 Connection Diagram
4 Sample Code
Introduction
The MQ6 is a simple-to-use liquefied petroleum gas (LPG) sensor. It can be used in gas leakage
detecting equipment in consumer and industry applications,this sensor is suitable for detecting LPG,
iso-butane, propane, LNG. Avoid the noise of alcohol, cooking fumes and cigarette smoke. The
sensitivity can be adjusted by the potentiometer.
Specification
Power supply needs: 5V
Interface type: Analog
Pin Definition: 1-Output 2-GND 3-VCC
High sensitivity to LPG, iso-butane, propane
Small sensitivity to alcohol, smoke
Fast response
Stable and long life
Simple drive circuit
Pin Definition
1. Signal Output
2. GND
3. Power
Analog Sensor Pin Definition
Connection Diagram
Analog sensor connection diagram
Sample Code
///Arduino Sample Code
void setup()
Serial.begin(9600); //Set serial baud rate to 9600 bps
void loop()
int val;
val=analogRead(0);//Read Gas value from analog 0
Serial.println(val,DEC);//Print the value to serial port
delay(100);
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0131”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+60.606651+7.87867
