Relay Module (Arduino Compatible) (SKU: DFR0017)
Contents
1 Introduction
2 Specification
3 Tutorial
3.1 Connection Diagram
3.2 Sample Code
3.3 Result
Introduction
The DFRobot Single Relay blocks the number of electronic modules. It can be used in interactive
projects. This relay shield uses Omron G5LA high-quality relay. It can also be used to control the
lighting, electrical and other equipments. The modular design makes it easy to expand with the
Arduino board (not included). The Relay output state by a light-emitting diode. It can be controlled
through the digital IO port, such as solenoid valves, lamps, motors and other high current or high
voltage devices.
Specification
Type: Digital
Single relay board
Rated through-current: 10A (NO) 5A (NC)
Maximum switching voltage: 150VAC 24VDC
Digital interface
Control signal: TTL level
Rated load: 8A 150VAC (NO) 10A 24VDC (NO), 5A 250VAC (NO/NC) 5A 24VDC (NO/NC)
Maximum switching power: AC1200VA DC240W (NO) AC625VA DC120W (NC)
Contact action time: 10ms
Module pin definitions: Pin1 - control side, Pin2 - Power supply (VCC), Pin3 - ground
Tutorial
Connection Diagram
Sample Code
//Arduino Sample Code
//www.DFRobot.com
//Last modified on 14th March 2012 by HJS
//This code has been updated to work with the sample code provided in the Wik
i
int Relay = 3;
void setup()
pinMode(13, OUTPUT);
//Set Pin13 as output
digitalWrite(13, HIGH);
//Set Pin13 High
pinMode(Relay, OUTPUT);
//Set Pin3 as output
void loop()
digitalWrite(Relay, HIGH);
//Turn off relay
delay(2000);
digitalWrite(Relay, LOW);
//Turn on relay
delay(2000);
Result
Every two seconds, LED will be turned on and off.
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0017”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+44.302901+5.49180
- 国内价格 香港价格
- 1+24.924261+3.08962
