Joystick Module For Arduino SKU:DFR0061
Contents
1 Introduction
2 Specification
3 PinOut
4 Tutorial
4.1 Connection Diagram
4.2 Sample Code
5 Trouble shooting
6 More
Introduction
Lots of robot projects need joystick. This module provides a affordable solution to that. Simply
connect to two analog inputs, the robot is at your commands with X,Y control. It also has a switch
that is connected to a digital pin. This joystick module can be easily connect to Arduino by IO
Expansion Shield For Arduino(V5) (SKU: DFR0088) with supplied cables.
Specification
Supply Voltage: 3.3V to 5V
Interface: Analog x2,Digital x1
PH2.0 Interface
Weight:15g
PinOut
Pin X
S——Analog OUT
GND——GND
VCC——VCC
Pin Y
S——Analog OUT
GND——GND
VCC——VCC
Pin Z
DATA——Digital OUT
VCC——VCC
GND——VCC
Tutorial
Connection Diagram
连线图说明
Pin X
S——A1
GND——GND
VCC——VCC
Pin Y
S——A0
GND——GND
VCC——VCC
Pin Z
DATA——D3
VCC——VCC
Sample Code
Libary installation
// # Editor
: Lauren from DFRobot
// # Date
: 17.01.2012
// # Product name: Joystick Module
// # Product SKU : DFR0061
GND——VCC
// # Version
: 1.0
// # Description:
// # Modify the Sample code for the Joystick Module
// # Connection:
X-Axis
-> Analog pin 0
Y-Axis
-> Analog pin 1
Z-Axis
-> Digital pin 3
int JoyStick_X = 0; //x
int JoyStick_Y = 1; //y
int JoyStick_Z = 3; //key
void setup()
pinMode(JoyStick_Z, INPUT);
Serial.begin(9600); // 9600 bps
void loop()
int x,y,z;
x=analogRead(JoyStick_X);
y=analogRead(JoyStick_Y);
z=digitalRead(JoyStick_Z);
Serial.print(x ,DEC);
Serial.print(",");
Serial.print(y ,DEC);
Serial.print(",");
Serial.println(z ,DEC);
delay(100);
Trouble shooting
More question and cool idea,visit DFRobot Forum
Powered By DFRobot © 2008-2016
很抱歉,暂时无法提供与“DFR0061”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+65.454711+8.50890
