Analog Gas Sensor(MQ4) (SKU:SEN0129)
Contents
1 Introduction
1.1 Specification
2 Pin Definition
3 Potentiometer
3.1 Connection Diagram
3.2 Sample Code
Introduction
The MQ4 is used in gas leakage detecting equipment in consumer and industry markets,this sensor
is suitable for detecting CH4,Natural gas, LNG, avoid exposure to alcohol, cooking fumes, and
cigarette smoke. The sensitivity can be adjusted by the potentiometer.
Specification
Power supply needs: 5V
Interface type: Analog
Pin Definition: 1-Output 2-GND 3-VCC
High sensitivity to CH4£¬Natural gas
Small sensitivity to alcohol, smoke
Fast response
Stable and long life
Simple drive circuit
Pin Definition
1. Signal Output
2. GND
3. Power
Analog Sensor Pin Definition
Potentiometer
Potentiometer is used to calibrate the readings from this sensor as stated on the datasheet:
SENSITVITY ADJUSTMENT
Resistance value of MQ-4 is difference to various kinds and various concentration gases. So,When
using this components, sensitivity adjustment is very necessary. we recommend that you calibrate
the detector for 5000ppm of CH4 concentration in air and use value of Load resistance ( RL) about
20KΩ(10KΩ to 47KΩ). When accurately measuring, the proper alarm point for the gas detector
should be determined after considering the temperature and humidity influence.
Connection Diagram
Analog sensor connection diagram
Sample Code
///Arduino Sample Code
void setup()
Serial.begin(9600); //Set serial baud rate to 9600 bps
void loop()
int val;
val=analogRead(0);Read Gas value from analog 0
Serial.println(val,DEC);//Print the value to serial port
delay(100);
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“SEN0129”相匹配的价格&库存,您可以联系我们找货
