DFR0229
DFR0229
    DFROBOT
    MICROSDCARDMODULEFORARDUINO
DFR0229 数据手册
    MicroSD card module for Arduino (SKU:DFR0229)  Contents     1 Introduction 2 Specification 3 Tutorial 3.1 Diagram 3.2 Sample Code 3.3 Result 4 Trouble shooting Introduction This is a Micro SD(TF) module from DFRobot. It is compatible with TF SD card (commonly used in Mobile Phone) which is the most tiny card in the market. SD module has various applications such as data logger, audio, video, graphics. This module will greatly expand the capbility an Arduino can do with their poor limited memory. This module has SPI interface and 5V power supply which is compatible with Arduino UNO/Mega. The Pinout is fully compatiblw with DFRobot's IO Expansion Shield V5. Specification     Working Voltage:5V Size:20x28mm Interface: SPI Compatible: MicroSD(TF) Tutorial Diagram     SDmodule Arduino MISO D12 SCK D13 SS chipSelect D4 MOSI D11 GND GND VCC 5V NOTE: Different Boards may have different SPI pin map, please check the datasheet of your controller. Sample Code How to install Library? Open the sample sketch "CardInfo"in the Arduino IDE. As you can see, it include the SD library called SD.h, you could also download other open source library on the web. /* SD card test This example shows how use the utility libraries on which the' SD library is based in order to get info about your SD card. Very useful for testing a card when you're not sure whether its working or n ot. The circuit: * SD card attached to SPI bus as follows: ** MOSI - pin 11 on Arduino Uno/Duemilanove/Diecimila ** MISO - pin 12 on Arduino Uno/Duemilanove/Diecimila ** CLK - pin 13 on Arduino Uno/Duemilanove/Diecimila ** CS - depends on your SD card shield or module. Pin 4 used here for consistency with other Arduino examples created 28 Mar 2011 by Limor Fried modified 9 Apr 2012 by Tom Igoe */ // include the SD library: #include // set up variables using the SD utility library functions: Sd2Card card; SdVolume volume; SdFile root; // change this to match your SD shield or module; // Arduino Ethernet shield: pin 4 // Adafruit SD shields and modules: pin 10 // Sparkfun SD shield: pin 8 const int chipSelect = 4; void setup() { // Open serial communications and wait for port to open: Serial.begin(9600); while (!Serial) { ; // wait for serial port to connect. Needed for Leonardo only } Serial.print("\nInitializing SD card..."); // On the Ethernet Shield, CS is pin 4. It's set as an output by default. // Note that even if it's not used as the CS pin, the hardware SS pin // (10 on most Arduino boards, 53 on the Mega) must be left as an output // or the SD library functions will not work. pinMode(10, OUTPUT); // change this to 53 on a mega // we'll use the initialization code from the utility libraries // since we're just testing if the card is working! if (!card.init(SPI_HALF_SPEED, chipSelect)) { Serial.println("initialization failed. Things to check:"); Serial.println("* is a card is inserted?"); Serial.println("* Is your wiring correct?"); Serial.println("* did you change the chipSelect pin to match your shield or module?"); return; } else { Serial.println("Wiring is correct and a card is present."); } // print the type of card Serial.print("\nCard type: "); switch(card.type()) { case SD_CARD_TYPE_SD1: Serial.println("SD1"); break; case SD_CARD_TYPE_SD2: Serial.println("SD2"); break; case SD_CARD_TYPE_SDHC: Serial.println("SDHC"); break; default: Serial.println("Unknown"); } // Now we will try to open the 'volume'/'partition' - it should be FAT16 or FAT32 if (!volume.init(card)) { Serial.println("Could not find FAT16/FAT32 partition.\nMake sure you've f ormatted the card"); return; } // print the type and size of the first FAT-type volume uint32_t volumesize; Serial.print("\nVolume type is FAT"); Serial.println(volume.fatType(), DEC); Serial.println(); volumesize = volume.blocksPerCluster(); locks // clusters are collections of b volumesize *= volume.clusterCount(); volumesize *= 512; 512 bytes // we'll have a lot of clusters // SD card blocks are always Serial.print("Volume size (bytes): "); Serial.println(volumesize); Serial.print("Volume size (Kbytes): "); volumesize /= 1024; Serial.println(volumesize); Serial.print("Volume size (Mbytes): "); volumesize /= 1024; Serial.println(volumesize); Serial.println("\nFiles found on the card (name, date and size in bytes): " ); root.openRoot(volume); // list all files in the card with date and size root.ls(LS_R | LS_DATE | LS_SIZE); } void loop(void) { } Result If your SD card is good and wiring is correct, open the Arduino IDE serial monitor, then you can see your SD card information. Or you might get this warn shown in the right picture.  Success  Failure Trouble shooting For any questions and more cool ideas to share, please visit DFRobot Forum Powered By DFRobot © 2008-2017
DFR0229 价格&库存
很抱歉,暂时无法提供与“DFR0229”相匹配的价格&库存,您可以联系我们找货
DFR0229
  • 1+49.014241+6.37320
  • 3+43.278533+5.62740
库存:30
DFR0229
    • 1+39.62465
    库存:68
