DFR0375
DFR0375
    DFROBOT
    COOKIE-IOEXPANSIONSHIELD
DFR0375 数据手册
  Cookie I/O Expansion Shield V2 SKU: DFR0375 Contents        1 Introduction 2 Features 3 Pin Definitions 4 Details 4.1 Digital & Analog 4.2 3.3V / 5V Power Switching 5 Cookie I/O Expansion Shield Applications 6 FAQ 7 More Introduction The Cookie I/O expansion shield is designed for beginners to electronics. The shield is directly compatible with the Boson kit. We have implemented fail-safe systems to prevent bad connections from destroying the board. The board is protected from reverse voltage input. And connector ports only accept connections the correct way around. These fail safes make the board ideal for beginners and classroom settings - no need to worry about your students making the wrong connections! Features      6 x PH2.0-3P interface digital ports: D3, D5, D6, D9, D10, D11 6 x PH2.0-3P Interface analog ports: A0 - A5 Two I2C ports, PH2.0-4P Interface 5V or 3.3V power supply (selected via power jumper cap) Size: 58 * 52 mm / 2.28 * 2.04 inches Pin Definitions    Details Digital & Analog     "D": represents digital signal "A": represents analog signal One of the biggest benefits of the I/O expansion shield is increased power and GND pins, allowing you to connect more sensors. * Green: digital signal * Blue: analog signal * Red: VCC * Black: GND  This is DFRobot's Gravity Interface. Digital and analog connections are easy to recognize and support most of DFRobot's I/O expansion shields and modules. Search "Gravity" in the DFRobot store to find compatible modules. 3.3V / 5V Power Switching The shield is compatible with 3.3V and 5V logic. Select desired voltage by shorting either the 3.3 or 5v pins as pictured. Cookie I/O Expansion Shield Applications You will need:   Hardware UNO Dashboard x1 DFR0375 Expansion Shield x1 Analog Sensors (Ambient Light Sensor) x1 Jumper Cables  Software Arduino IDE V1.6.5 click to download Arduino IDE Sample Code 1 int light=0; 2 3 void setup() { 4 // put your setup code here, to run once: 5 pinMode(3,OUTPUT); 6 Serial.begin(9600); 7 } 8 void loop() { 9 // put your main code here, to run repeatedly: 10 light=analogRead(0); 11 Serial.println(light); 12 if(light>100) 13 digitalWrite(3,HIGH); 14 else digitalWrite(3,LOW); 15 delay(100); 16 } When there is low ambient light, the LED will turn ON. FAQ For any questions/advice/cool ideas to share, please visit DFRobot Forum. Powered By DFRobot © 2008-2017
DFR0375 价格&库存
很抱歉,暂时无法提供与“DFR0375”相匹配的价格&库存,您可以联系我们找货
