SEN0205
SEN0205
    DFROBOT
    GRAVITY:ANALOGLIQUIDLEVELSEN
SEN0205 数据手册
  Liquid Level Sensor‐FS‐IR02 SKU: SEN0205 From Robot Wiki    Contents     1 Introduction  2 Specification  3 Board Overview  4 Tutorial   o 4.1 Installation  o 4.2 Requirements  o 4.3 Sample Code  o 4.4 Expected Results  Introduction This is a photoelectric liquid level sensor that is operates using optical principles. The advantages of this are good sensitivity and no need for mechanical parts - meaning less calibration! The corrosion resistant probe is easily mounted and can handle high temperature and high pressure. The sensor is equipped with an interface adapter for compatibility with the DFRobot "Gravity" interface. Note: Avoid placing the sensor near bright lights or in direct sunlight as these can cause interference. Specification            Model: FS‐IR02  Type: Photoelectric Liquid Level Sensor  Operating Voltage: 5V DC  Output Current: 12mA  Operating Temperature: ‐ 25 ~ 105    Low Level Output:  4.6 V  Liquid Level Detection Accuracy: ±0.5 mm  Material: Polycarbonate  Measuring Range: No limit  Life: 50,000 hours  Board Overview       Liquid Level Sensor‐FS‐IR02 Pin Mappings  Num.  1 (Red)     Liquid Level Sensor‐FS‐IR02        Name  Description   GND   Probe_GND   2 (Yellow)   GND   Probe_GND   3 (Blue)     VCC   4 (Whitel)   OUT   Probe_VCC   Signal Output     Liquid Level Sensor‐FS‐IR02 convert board  Liquid Level Sensor‐FS‐IR02 Pin Mapping  Num.  Name  Description   Left_1   GND   Probe_GND   Left_2   GND   Probe_GND   Left_3   VCC   Probe_VCC   Left_4   IN   Signal Input   Right_1   OUT   Signal Output   Right_2   VCC   VCC   Right_3   GND   GND   Liquid Level Sensor-FS-IR02 convert board Tutorial Installation       Requirements   Hardware   o DFRduino UNO x1  o Liquid Level Sensor‐FS‐IR02 x1  Software   o Arduino IDE Click to Download Arduino IDE from Arduino®  o https://www.arduino.cc/en/Main/Software  Sample Code /*************************************************** 2 * Liquid Level Sensor-FS-IR02 3 * **************************************************** 4 * This example is to get liquid level 5 6 * @author jackli(Jack.li@dfrobot.com) 7 * @version V1.0 8 * @date 2016-1-30 9 10 * GNU Lesser General Public License. 11 * See for details. 12 * All above must be included in any redistribution 13 * ****************************************************/ 14 int Liquid_level=0; 15 void setup() { 16 Serial.begin(9600); 17 pinMode(5,INPUT); 18 } 19 20 21 22 23 void loop() { Liquid_level=digitalRead(5); Serial.print("Liquid_level= ");Serial.println(Liquid_level,DEC); delay(500); 24 } Expected Results When liquid comes in to contact with the sensor probe the microcontroller will output HIGH logic. When the liquid is not in contact with the probe the microcontroller will output LOW logic. FAQ For any questions, advice or cool ideas to share, please visit DFRobot Forum. Powered By DFRobot © 2008-2017
SEN0205 价格&库存
很抱歉,暂时无法提供与“SEN0205”相匹配的价格&库存,您可以联系我们找货
SEN0205
  • 1+65.193931+8.47500
库存:26
