Quad Motor Driver Shield for Arduino SKU:DRI0039
From Robot Wiki
Contents
1 Introduction
2 Specification
3 Board Overview
4 Tutorial
o 4.1 You Will Need
o 4.2 Connection Diagram
o 4.3 Sample Code
o 4.4 Result
5 FAQ
Introduction
The latest quad motor driver shield for Arduino, compatible with 5V/3.3V Arduino controller,
can control up to four DC motors with 8 pins at the same time. The shield supports PWM speed
control and polarity control. The driver shield includes two TB6612FNG motor driver chips,
compared with the traditional L298N chip, efficiency is improved and the component size also
greatly reduced. The chip doesn't heat in to the rated range, and a single path maximum output
1.2A continuous current. The module includes a built-in low voltage detection circuit and
thermal shutdown protection circuit, which is safe and reliable. This module is suitable for all
kinds of DIY production.
Specification
VM Motor Power Supply: 2.5 V ~ 13.5 V
VCC Logic Power Supply: 2.7 ~ 5.5 V
Output Current: 1.2A continuous current (per channel)
Start/Peak Current: 2A (continuous pulse) / 3.2A (single pulse)
Arduino Control Port: Digital pins 3, 4, 5, 6, 7, 8, 11, 12
Working Temperature: ‐20 ~ 85
Dimensions: 53mm x 52mm/2.09 x 2.05
Board Overview
Motor I/O
Motor
Direction
Forward
Backward
Speed
Speed range
M1
4
LOW
HIGH
3
0‐255
M2
12
HIGH
LOW
11
0‐255
M3
8
LOW
HIGH
5
0‐255
M4
7
HIGH
LOW
6
0‐255
Tutorial
You Will Need
Hardware
o DFRduino UNO R3 x 1
o Quad Motor Shield for Arduino x 1
o DC motor x 4
o Jumper Wires
Software
o Arduino IDE Click to download Arduino IDE https://www.arduino.cc/en/Main/Software
Connection Diagram
Sample Code
Sample Code
1 /*!
2 * @file QuadMotorDriverShield.ino
3 * @brief QuadMotorDriverShield.ino
Motor control program
4 *
5 * Every 2 seconds to control motor positive inversion
6 *
7 * @author linfeng(490289303@qq.com)
8 * @version
9 * @date
V1.0
2016-4-5
10 */
11 const int E1 = 3; ///
很抱歉,暂时无法提供与“DRI0039”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+180.456801+23.45880
- 3+159.247053+20.70160
- 国内价格 香港价格
- 1+130.644001+16.98330
