M K R R E L AY P R OTO S H I E L D
Code: TSX00003
The MKR Relay Proto Shield allows you to easily command relays
with your MKR board. The shield provides two on board relays and a
small prototyping area if you need to add some other component to
your project.
The MKR Relay Protoshield allows you to easily add relays to your MKR board
based project. The shield provides two relays
called RELAY1 and RELAY2 commanded by pin 1 and pin 2respectively. The shield
also provides easy connection by means of screw terminal blocks
to A1 toA4 analog inputs, I2C and supply voltages.
Operating voltage 3.3V (supplied from the host board)
Two relays with NO, COM and NC connections
Works with battery powered board
Screw terminal blocks for easy connections
Carry current: 2 A
Max. operating voltage: 125 VAC, 60 VDC
Max. operating current: 1 A
Max. switching capacity: 62.50 VA, 30W
You can find here your board warranty informations.
https://www.arduino.cc/en/Main/warranty
OSH: Schematics
MKR Relay Proto Shield is open‐source hardware! You can build your own board
using the following files:
EAGLE FILES IN .ZIP
https://www.arduino.cc/en/uploads/Main/MKRRelayProtoShield.zip
SCHEMATICS IN .PDF
https://www.arduino.cc/en/uploads/Main/MKRRelayProtoShield‐schematic.pdf
https://store.arduino.cc/usa/mkr‐relay‐proto‐shield 12‐8‐17
很抱歉,暂时无法提供与“TSX00003”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+173.900411+21.75839
- 10+170.3818310+21.31815
- 25+167.4839125+20.95556
- 50+165.0581950+20.65206
- 国内价格
- 1+147.34538
- 10+146.29359
- 25+145.46048
