Input Shield For Arduino SKU: DFR0008
Contents
1 Introduction
2 Specification
3 Pin Allocation
4 Sample Code1
5 Sample Code2
6 Version history
Introduction
The upgraded Arduino Input Shield includes a two axis mini joystick (with moment switch) as well as
four colored push buttons(Red,Yellow,Blue,Green). The reserved APC220 Radio Data
Module(SKU:TEL0005) interface and the Xbee interface is deisgned to facilitate the realization of
wireless rocker button controller. The shield can be easily stacked on top of your Arduino boards. It
can also connect with OLED2864 & OLED9664.
Specification
Dual axis mini joystick
Connects to your Arduino using male to male pin headers
Comes with 2 colored push buttons
The use of imported high-quality potentiometers and the PS button rocker. The rocker output an
analog signal is *to achieve vertical and horizontal control, which is attached to four keys at the
same time. It also has two *great circle button caps (cap color random round keys), a rocker button
and a reset button.
The use of stack design is so that the plug can easily on Arduino Duemilanove or DFRduino Romeo.
The reserved APC220/Bluetooth module interface is to facilitate the realization of wireless rocker
button controller.
The remaining unused ports are extended out of standby.
Pin Allocation
Pin
Function
Digital 8
Analog 1
Digital 9
Digital 12
Analog 3
Analog 2
UP
Down
Left
Right
X axis
Y axis
Sample Code1
function:
by:
created:
test dfr0008
lisper (leyapin@gmail.com)
2013-11-04
#define up_button
8
#define down_button
A1
#define left_button
9
#define right_button
12
#define stick_button
A0
#define level_stick
A3
#define vertical_stick A2
void setup () {
Serial.begin (9600);
pinMode (left_button, INPUT);
pinMode (right_button, INPUT);
pinMode (up_button, INPUT);
pinMode (down_button, INPUT);
pinMode (stick_button
, INPUT);
pinMode (level_stick
, INPUT);
pinMode (vertical_stick, INPUT);
void loop () {
int left_state = digitalRead (left_button);
int right_state = digitalRead (right_button);
int up_state = digitalRead (up_button);
int down_state = digitalRead (down_button);
int stick_state = digitalRead (stick_button);
int level_value = analogRead (level_stick);
int vertical_value = analogRead (vertical_stick);
Serial.print ("up=");
Serial.print (up_state);
Serial.print (" down=");
Serial.print (down_state);
Serial.print (" left=");
Serial.print (left_state);
Serial.print (" right=");
Serial.print (right_state);
Serial.print (" stick=");
Serial.print (stick_state);
Serial.print ("
vertical=");
Serial.print (vertical_value);
Serial.print (" level=");
Serial.println (level_value);
delay (500);
Sample Code2
function:
by:
created:
test dfr0008
2013-11-04
#include
#define up_button
8
#define down_button
A1
#define left_button
9
12
#define stick_button A0
#define level_stick A3
int vertical_value=0;
//current value
int level_value=0;
//current value
int vertical_valuep=0; //previous value
int level_valuep=0;
//previous value
uint16_t key_delay_time = 20; // for ispressed ()
void setup () {
pinMode (stick_button, INPUT);
pinMode (level_stick, INPUT);
void loop () {
if (vertical_value != vertical_valuep) {
Serial.print ("vertical=");
Serial.println (vertical_value);
if (level_value != level_valuep) {
Serial.print ("level=");
vertical_valuep = vertical_value;
level_valuep = level_value;
if (ispressed (up_button))
Serial.println ("up pressed");
if (ispressed (down_button))
Serial.println ("down pressed");
if (ispressed (left_button))
Serial.println ("left pressed");
if (ispressed (right_button))
Serial.println ("right pressed");
if (ispressed (stick_button))
Serial.println ("stick pressed");
delay (10);
//check button
boolean ispressed (uint8_t key) {
if (digitalRead (key) == 0) {
delay (key_delay_time);
return true;
return false;
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0008”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+46.547171+6.03420
