SEN0202
SEN0202
    DFROBOT
    3DGESTURESENSOR(MINI)FORARD
SEN0202 数据手册
    3D Gesture Sensor Mini SKU: SEN0202 3D Gesture Sensor mini Contents      1 Introduction 2 Specification 3 Board Overview 4 Tutorial 4.1 Requirements 4.2 Connection Diagram 4.3 Sample Code 4.4 Results 5 FAQ Introduction The DFRobot 3D gesture sensor is an interactive sensor that integrates 3D gesture recognition and motion tracking. This sensor can be used to detect clockwise/counterclockwise rotation and movement directions. The gesture sensor is designed based on Microchip patent GestIC® technology, using electric near field sensing technology, including 3D gesture input sensing system and advanced 3D signal processing unit. The effective detection range is 0-10cm. This sensor can be applied to various interactive projects. Specification    Operating Voltage: 3.3 - 5V Interface Type: I2C I2C Address: 0x42      Gesture Detection Range: 5cm Distance Induction Range: 10cm Dimensions : 72 x 54 mm / 2.83 x 2.12" Operating Temperature: - 20 ~ + 85 Spatial Resolution: 150 dpi Board Overview No. Label Description 1 GND GND 2 VCC VCC(5V) 3 MCLR Sensor Reset(Low Level On) 4 SCL I2C clock signal 5 SDA I2C data signal 6 D Digital IO Sensor address:0X42 Tutorial Requirements  Hardware DFRduino UNO x 1 3D Gesture Sensor Mini x1 Dupont jumper wires  Software Arduino IDE Click to download Arduino IDE https://www.arduino.cc/en/Main/Software Connection Diagram 3D Gesture Sensor mini Sample Code Click to download the library sample and library(Github). How to intall libraries? https://github.com/DFRobot/DFRobot_Gesture This code will recognize the direction of gestures: up, down, left, right, clockwise and counterclockwise 1 #include 2 #include 3 4 int testPin= 7; 5 unsigned char cmd; 6 7 DFRobot_Gesture myGesture; 8 9 void setup() 10 { 11 Wire.begin(); // join i2c bus (address optional for master) 12 Serial.begin(9600); // start serial for output 13 pinMode(testPin, INPUT); 14 Serial.write("3D Gesture sensor is now running....\r\n"); 15 } 16 17 void loop() 18 { 19 if(digitalRead(testPin)==0) 20 { 21 myGesture.I2C1_MasterRead(md.buf,26,0x42); //The address is:0x42 22 cmd = myGesture.mgcProcMsg(); 23 24 if(cmd != GI_NOGESTURE ) { //process the message 25 switch(cmd) 26 { 27 case GI_FLICK_R: 28 Serial.println("RIGHT"); 29 break; 30 case GI_FLICK_L: 31 Serial.println("LEFT"); 32 break; 33 case GI_FLICK_D: 34 Serial.println("DOWN"); 35 break; 36 case GI_FLICK_U: 37 Serial.println("UP"); 38 break; 39 case GI_AIRWHEEL_CW://Clockwise in circles 40 Serial.println("CW"); 41 break; 42 case GI_AIRWHEEL_CCW://Counterclockwise circles 43 Serial.println("CCW"); 44 break; 45 46 default: break; 47 } 48 } 49 } 50 else {}; 51 } Results Use your hand to move up and down or clockwise and counterclockwise, the serial port will output the corresponding string. FAQ For more questions or interesting projects, you can Visit the forum                                           Powered By DFRobot © 2008-2017
SEN0202 价格&库存
很抱歉,暂时无法提供与“SEN0202”相匹配的价格&库存,您可以联系我们找货
