Bees Shield SKU:DFR0210
Contents
1 Introduction
2 Specification
3 Board Overview
4 Tutorial
4.1 Requirements
4.2 Bee1 Hardware Serial Port; Bee2 Software Serial Port
4.2.1 Connection Diagram
4.2.2 Sample Code
4.2.3 Result
4.3 Bee2 Hardware Serial Port; Bee1 Software Serial Port
4.3.1 Connection Diagram
4.3.2 Sample Code
4.3.3 Result
4.4 Bees Using The Hardware Serial Port Alternately
4.4.1 Connection Diagram
4.4.2 Sample Code
4.4.3 Result
5 FAQ
Introduction
Have you ever been in a situation where you need two communication methods for your project?
How about when a serial port is occupied by another serial device, and you still need to setup
wireless communication?
The DFRobot Bees shield can solve these problems. The Bees shield is compatible with Arduino
boards such as UNO R3 and Leonardo it has a large prototyping shield giving you plenty of space to
experiment and add extra components to your project.
Thanks to its uniform interface, there are a huge number of devices compatible with the xBee
socket: xBee, WiFi xBee, Bluetooth Bee, zigBee, etc.
The Bees shield is also stackable giving you more flexibility with your projects. Although it is an old
design, it is still very practical!
Specification
Operating Voltage: 3.3V~5V
xBee slots: 2
Serial port: Hardware Serial port and Software Serial port
Arduino compatible
DIP prototyping area
Dimension: 92 mm * 56 mm/ 3.62 inches * 2.2 inches
NumLabel
1 LED
2 LED
3 RUN/PROG Switch
Description
Bee1 Indicator LED
Bee2 Indicator LED
Programming Switch
Hardware Serial Port Enable Pin for Bee1
4 EN
and Bee2
5 xBee TX & RX
xBee_TX and xBee_RX pins
Bee1 Hardware/Software Serial "A" → Hardware Serial Port
6
Port Switch
"S" → Software Serial Port
Bee2 Hardware/Software Serial "A" → Hardware Serial Port
7
Port Switch
8 Reset
Arduino Reset
Short DTR when you need the wireless
9 Wireless Programming
programming function
Note:
3. Programmable Switch:
Set the switch to "PROG" when you upload a program
Set the switch to "RUN", when you use the hardware serial port
5. xBee TX & RX: The silk-screen shows the xBee RX & TX pins, which connect to the
Arduino TX & RX ones. It means if you define D2 as Arduino_RX in the code, you should
connect to D2 to xBee_TX on the shield. The same goes for Arduino_TX.
Tutorial
In this Tutorial, we will use two BLE Link modules as wireless modules
Requirements
Hardware
UNO x1
Bees Shield x1
BLE LINK x2
Android or iOS device x1
Software
Arduino IDE V1.6.5 Click to Download Arduino IDE from Arduino®
Install the APK file into your Android phone
Compile the source code into your Apple device
Connection Diagram
If you need Bee1 working with the hardware serial port, and Bee2 working with the software serial
port, you can change the jumpers and switches like so:
Sample Code
# This sample code is used to test the Bees shield.
# Editor : Mickey
# Ver
: 1.0
# Product: Bees shield
# SKU
: DFR0210
# The circuit:
software RX is digital pin 2 (connect to TX of Bee2 device)
software TX is digital pin 3 (connect to RX of Bee2 device)
#include
SoftwareSerial mySerial(2, 3); // UNO RX -- Bee TX, UNO TX -- Bee RX
void setup()
Serial.begin(115200);
mySerial.begin(115200);
delay(50);
void loop()
Serial.println("this is Bee1 hardware!");
mySerial.println("this is Bee2 software!");
delay(500);
Result
Connection Diagram
If you need Bee1 working with the software serial port, and Bee2 working with the hardware serial
Sample Code
# Editor : Mickey
# Ver
: 1.0
# SKU
: DFR0210
# The circuit:
software RX is digital pin 2 (connect to TX of Bee1 device)
software TX is digital pin 3 (connect to RX of Bee1 device)
#include
void setup()
delay(50);
void loop()
Serial.println("this is Bee2 hardware!");
mySerial.println("this is Bee1 software!");
delay(500);
Result
Connection Diagram
If you need both BLE LINK modules working with the hardware serial port alternately, you can
(You can select a pin from digital 4-12 as the xBee Enable pin to make them work. The following
example uses "D4".
Sample Code
# This sample code is used to test an Arduino hardware serial switch.
# Editor : Mickey
# Ver
: 1.0
# SKU
: DFR0210
void setup()
pinMode(4, OUTPUT);
delay(500);
void loop()
digitalWrite(4, LOW);
Serial.println(" ");
delay(500);
digitalWrite(4, HIGH);
delay(500);
Result
NOTE: The Bees Shield only has three modes above. Currently it is not possible to make two
Bees work with the software serial port at the same time.
FAQ
There are no questions about this product yet. If you have any problems or suggestions, you are
welcome to email us or post on the DFRobot forum!
For any questions/advice/cool ideas to share, please visit the DFRobot Forum or email
techsupport@dfrobot.com
Powered By DFRobot © 2008-2017
很抱歉,暂时无法提供与“DFR0210”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.206881+3.79680
- 国内价格 香港价格
- 1+78.145971+10.15873
