101020132
101020132
    SEEED(矽递科技)
    GROVELIGHTSENSORVER1.2
101020132 数据手册
            Grove - Light Sensor v1.2 SKU 101020132    Description  As an updated version of Grove ‐ Light Sensor 1.0, the Grove ‐ Light Sensor v1.2 is also aimed at  measuring light levels, however with higher reliability and sensibility. It is an analog module and  output various electrical signals which can be converted to different ranges (It depends on the  Analog‐to‐Digital‐Converter on your controller board. For example, it can output 0‐255 for an 8‐ bit ADC). It integrates a high‐sensitive and reliable phototriode, and just like other grove  modules, it is interfaced with Grove port which can save you a lot work in wiring.     Features      Easy to use since it is interfaced with Grove port.  High reliability and sensibility.  Small footprint  Recognize wider spectrum.        Technical Details  Dimensions  20mm x 20mm x 18mm  Weight  G.W 8g     N.W 4g  Battery  Exclude  Operating voltage(V)  3‐5 V  Operating current(mA)  0.5‐3 mA  Response time  20 ~ 30 milliseconds  Peak Wavelength  540 nm  Phototriode  GL5528(datasheet)  Part List  Grove ‐ Light Sensor V1.2  1  Grove Cable  1  ECCN/HTS      ECCN  EAR99  HSCODE  9031809090        https://www.seeedstudio.com/Grove‐Light‐Sensor‐v1.2‐p‐2727.html 11‐23‐18
101020132 价格&库存
很抱歉,暂时无法提供与“101020132”相匹配的价格&库存,您可以联系我们找货
库存:13
101020132
    • 1+21.16092
    库存:62
