101020172
101020172
    SEEED(矽递科技)
    GROVE-LINEFINDERV1.1
101020172 数据手册
          Grove - Line Finder v1.1 SKU 101020172    Description  Most of automated robotic projects start from a line‐following robot, Grove ‐ Line finder v1.1 is  designed to achieve this task easily and quickly. Those eye‐like sensors on the board are  actually IR emitting LED and sensitive phototransistor. When the phototransistor detects the  reflected infrared light from the IR emitting LED, it will output a digital signal, which changes  from HIGH to LOW.    Features      Easy to use  Integrated indicator LED  Digital output  Adjustable detecting range.      Specifications        Power supply: 5V DC  Digital output mode: TTL (High when black is detected, Low when white is detected)  Connector: 4 pin Buckled Grove interface  Dimension: 20mm*20mm  Comparator: LMV358  Photo reflective diode: RS‐06WD    Technical Details  Dimensions 24.20mm x 20mm x 10.80mm  Weight  G.W 8g     N.W 8.30g  Battery  Exclude  Power supply  5V DC  Digital output mode  TTL (High when black is detected, Low when white is detected)  Connector  4 pin Buckled Grove interface  Comparator  MV358  Photo reflective diode  RS‐06WD  Part List  Grove ‐ Line Finder v1.1 1  ECCN/HTS      ECCN EAR99  HSCODE  9031900090        https://www.seeedstudio.com/Grove‐Line‐Finder‐v1.1‐p‐2712.html 11‐23‐18
101020172 价格&库存
很抱歉,暂时无法提供与“101020172”相匹配的价格&库存,您可以联系我们找货
  • 1+37.885061+4.89446
库存:389
101020172
    • 1+32.38704
    库存:96
