103990143
103990143
    SEEED(矽递科技)
    RASPBERRYPIVGA666DPIDTOVERLA
103990143 数据手册
Raspberry PI VGA666 DPI dtoverlays Module SKU 103990143  This Module has another name: Gert-VGA-adapter, or Passive VGA adapter 666 for Raspberry  Pi A+/B+/2B/3B/Zero The Raspberry Pi has an HDMI port to connect a display. If your monitor only has VGA, you have to use an adapter      Description This Module has another name: Gert-VGA-adapter, or Passive VGA adapter 666 for Raspberry Pi A+/B+/2B/3B/Zero The Raspberry Pi has an HDMI port to connect a display. If your monitor only has VGA, you have to use an adapter. Because this requires a digital-to-analogue conversion, those adapters can be quite pricey, and they can draw lots of power. As well as just allowing you to connect a VGA monitor natively. And unlike composite video, the DPI interface can be run independent of the HDMI. The software for dual screens is still under development. Running two screens at maximum resolution will depend on the speed of GPIO. This wasn’t possible on the Model A or B. And there’s a catch: as the board uses most of your GPIO pins, you lose access to them. All above are from raspberry pi official website. Features  Support for Raspberry Pi A+, Raspberry Pi B+, Raspberry Pi Zero, Raspberry Pi 2,model B, Raspberry Pi 3 model B  The VGA output supports resolution:from 800x600 up to 30fps.  With 6 bits per channel you have a maximum of 262144 colours.  Easy to setup.  Easy to configure.  Dimension: 64.00mm x 32.24mm  Weight: 16.48 g Part List 1 x VGA666 module                                           Copyright © 2008-2016 Seeed Development Limited All rights reserved
103990143 价格&库存
很抱歉,暂时无法提供与“103990143”相匹配的价格&库存,您可以联系我们找货
