Zero LiPo PIM185
The tiny little LiPo/LiIon power supply shim for all versions of the Raspberry Pi!
We love mobile projects but having a discrete, slick, and tidy power supply solution is always
tricky. The Zero LiPo aims to give you the most compact Raspberry Pi power supply possible.
You can either solder the 0.8mm thick PCB directly onto the GPIO pins on your Pi for a
permanent solution, or solder on the provided 2x4 0.1" female header which will allow you to
remove your Zero LiPo at any time (but will block the GPIO pins).
We use the TPS61232 step-up boost converter from Texas Instruments that offers up to 96%
efficiency. The board includes power on and battery low indicator LEDs. During shutdown (due
to under-voltage or external selection) the quiescent current is just 15uA sip.
The MagPi described Zero LiPo as "a slick bit of kit" and "a great option for providing safe
power for a portable project" in their four star review.
Need a battery? Check out our range of LiPo and LiIon batteries!
Features
0.8mm thick PCB
Shaped to sit as low as possible on the Raspberry Pi
2‐pole JST connector ideal for most LiPo/LiIon batteries
Power and low battery LED indicators
Supplies up to 1.5A continuous current (15uA quiescent current)
Low battery warning at 3.4V (asserts GPIO #4 low)
Automatic shutdown at 3.0V to protect your battery
VBAT+, GND, and EN pins available to break out
2x4 0.1" female header (optional, for non permanent installation)
Includes rubber foot to space Zero LiPo away from your Raspberry Pi
Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W
Requires soldering
Software
We've put together a one-line installer that will initiate a clean shutdown when the low battery
warning is triggered and GPIO #4 is pulled low. More details are available here in the GitHub
repository.
Notes
This is not a charger. You will need a separate charger to keep your LiPo/LiIon batteries topped
up! We recommend the Adafruit Micro Lipo or PowerBoost 1000 Charger.
https://shop.pimoroni.com/products/zero‐lipo 4/19/2017
很抱歉,暂时无法提供与“PIM185”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+138.4125610+17.90736
