Mini Black HAT Hack3r
Fully Assembled PIM169
Solder Yourself Kit PIM170
PCB only PIM171
Need to detach or debug your HAT? Then the Mini Black HAT Hack3r is for you!
A nifty little tool that lets you access all of the GPIO pins while also running a HAT. Ideal for debugging
your HAT projects or combining a HAT with other circuits.
HAT & pHAT landing areas with PCB standoffs
Includes 40 pin GPIO ribbon cable
All GPIO pins labelled with function, BCM pin number, physical pin number
Rubber non‐slip feet
4 mounting holes
Comes assembled or in kit form
We made this for ourselves when debugging new HAT designs but found it so gosh‐darn useful that we
thought you might like it too!
Kits include:
Black HAT Hack3r PCB
40‐way black GPIO ribbon cable
3 x 40‐way pin header (pre‐installed on the assembled version)
4 x PCB standoff for HAT mounting
4 x Rubber non‐slip feet
https://shop.pimoroni.com/products/mini-black-hat-hack3r 4/14/2017
很抱歉,暂时无法提供与“PIM169”相匹配的价格&库存,您可以联系我们找货
