MIKROE-2380
MIKROE-2380
    MIKRO
    ROTARYOCLICK
MIKROE-2380 数据手册
ROTARY click From MikroElektonika Documentation Rotary click carries a 15-pulse incremental rotary encoder with detents, surrounded by a ring of 16 orange LEDs. The board is available in five different LED colors: red, green, blue, yellow and orange. Rotary click Features and usage notes Rotary click with its LED ring is a perfect solution for implementing an input knob into your design (in contrast to a potentiometer, a rotary encoder can be spun round continuously). A single rotation is divided into 15 discrete steps. The encoder outputs A and B signals (out of phase to each other). The knob is also a push-button outputted through the interrupt line. The LED ring are controlled through the SPI interface. Schematic also available in PDF (http://cdndocs.mikroe.com/images/a/a3/Rotary_O_click_schem In addition to the SPI lines (CS, SCK, MISO, MOSI), Rotary clicks have three additional lines for outputting the Encoder info: ENCB OUT, ENCA OUT and SW (in place of the standard AN, RST and INT pins, respectively). Rotary click All Rotary click boards can be used with either a 3.3V or 5V power supply. The configuration is set up with an onboard jumper (zero ohm resistor). By default, it’s set to 3.3V IC/Module [Rotary encoder surrounded by ring of LEDs] Interface SPI, ENCA, ENCB Programming Power supply 3.3V, 5V The following code snippet demonstrates the write procedure of Rotary click. Website 1 void HC595_Write( int value ) 2 { 3 char first_byte, second_byte; 4 5 second_byte = value; 6 value = value >> 8; 7 first_byte = value; 8 SPI1_write( first_byte ); 9 SPI1_write( second_byte ); 10 HC595_cs = 0; 11 asm{ nop }; 12 asm{ nop }; 13 asm{ nop }; 14 HC595_cs = 1; 15 16 } www.mikroe.com/click/rotary-r (http://www.mikroe.com/click/rotary-r) www.mikroe.com/click/rotary-g (http://www.mikroe.com/click/rotary-g) www.mikroe.com/click/rotary-b (http://www.mikroe.com/click/rotary-b) www.mikroe.com/click/rotary-y (http://www.mikroe.com/click/rotary-y) www.mikroe.com/click/rotary-o (http://www.mikroe.com/click/rotary-o) Code examples that demonstrate the usage of Rotary click with MikroElektronika hardware, written for mikroC for ARM, AVR, dsPIC, FT90x, PIC and PIC32 are available on Libstock (http://libstock.mikroe.com/projects/view/1227/rotary-click). Resources - Rotary click Libstock example (http://libstock.mikroe.com/projects/view/1227/rotary-click) - mikroBUS™ standard specifications (http://download.mikroe.com/documents/standards/mikrobus/mikrobus-standard-specification-v200.pdf) - LEDs and bit shifting: a shift register tutorial (http://learn.mikroe.com/leds-bit-shifting-shift-register-tutorial/) http://docs.mikroe.com/ROTARY_click 9/15/2016
MIKROE-2380 价格&库存
很抱歉,暂时无法提供与“MIKROE-2380”相匹配的价格&库存,您可以联系我们找货
