GainAMP click
PID: MIKROE-2555
Weight: 25 g
GainAMP click carries the LTC®6912 dual channel, low noise, digitally programmable gain
amplifier (PGA). The click is designed to work on either 3.3V or 5V power supply. It
communicates with the target MCU over SPI interface, with additional functionality provided by
the following pins on the mikroBUS™ line: AN, RST.
GainAMP click also features three pairs of screw terminals and a power indication LED.
How it works
The gains for both channels are independently programmable, using a 3-wire SPI interface to
select voltage gains of 0, 1, 2, 5, 10, 20, 50, and 100V/V (LTC6912-1). All gains are inverting.
The LTC®6912 consists of 2 matched amplifiers with rail-to-rail outputs. When operated with
unity gain, they will also process rail-to-rail input signals.
A half-supply reference generated internally at the AGND pin supports single power supply
applications. Operating from single or split supplies from 2.7V to 10.5V total.
Programmable gain amplifier
A programmable-gain amplifier (PGA) is an electronic amplifier whose gain can be controlled
externally (by analog or digital signals).
Key features
LTC®6912 gain amplifier
o 2 Channels with Independent Gain Control
o 3‐Wire SPI Interface
o Extended Gain‐Bandwidth at High Gains
o Rail‐to‐Rail Input Range
o Rail‐to‐Rail Output Swing
o Single or Dual Supply: 2.7V to 10.5V Total
Screw terminals for input and output
SPI interface
Specification
Product Type Amplifier
Data Acquisition Systems, Dynamic Gain Changing, Automatic Ranging
Applications
Circuits, Automatic Gain Control.
MCU
LTC®6912 dual channel gain amplifier
Rail-to-Rail Output Swing, Rail-to-Rail Input Range, 2 Channels with
Key Features
Independent Gain Control, Three pairs of screw terminals, 3-wire SPI interface
Interface
SPI
Power Supply 3.3V or 5V
Compatibility mikroBUS
Click board
S (28.6 x 25.4 mm)
size
Pinout diagram
This table shows how the pinout on GainAMP click corresponds to the pinout on the
mikroBUS™ socket (the latter shown in the two middle columns).
Notes
Pin
Pin
Notes
mikroBUStm
Analog input AN_IN 1 AN
Shut down
SHDN
PWM 16 NC Not connected
2 RST
Chip select SPI_CS 3
INT 15 NC Not connected
CS
TX 14 NC Not connected
SPI Clock Input SPI_CLK 4 SCK
RX 13 NC Not connected
Not connected
5 MISO
SCL 12 NC Not connected
SPI Master Output Slave Input SPI_MOSI 6 MOSI
SDA 11 NC Not connected
NC
Power supply
+3.3V
7 3.3V
Ground
GND
8 GND
5V 10 +5V Power supply
GND 9 GND Ground
Maximum ratings
Description
Min Typ Max Unit
Total Supply Voltage (V+ to V–)
11V V
Input Current
±10
mA
Operating Temperature Range –40°C
85°C
Jumpers and settings
Designator Name Default Position Default Option
Description
JP1
AN_sel ON
AN
Analog input jumper.
JP2
V+
Left
VCC
V+ selection.
JP3
V‐
Left
GND
V‐ selection.
Programming
Code examples for GainAMP click, written for MikroElektronika hardware and compilers are
available on Libstock.
The gains for both channels are independently programmable using an SPI interface to select
voltage gains. The example controls channel A, increasing and decreasing gain with input
buttons.
Code snippet
The code snippet demonstrates a simple usage of the helper function.
01 void main()
02 {
03
system_init();
04
05
gain_amp_set(GAIN_AMP_NOMINAL_0, GAIN_AMP_SW_SHUTDOWN);
06
07
while( 1 )
08
09
if(Button(&GPIOE_IDR, 9, 100, 1))
10
11
byte = gain_amp_set(++gain & 0x07, GAIN_AMP_SW_SHUTDOWN);
12
GPIOD_ODR = (GPIOD_ODR & 0xFF00) | byte;
13
14
if(Button(&GPIOE_IDR, 8, 100, 1))
15
16
byte = gain_amp_set(--gain & 0x07, GAIN_AMP_SW_SHUTDOWN);
17
18
19
20 }
https://shop.mikroe.com/click/audio‐and‐voice/gainamp 4/5/17
很抱歉,暂时无法提供与“MIKROE-2555”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+185.86712
- 5+182.15099
