PIM138
PIM138
    PIMORONI
    PHATDAC(INDIVIDUAL)
PIM138 数据手册
    pHAT DAC PIM138 If music be the food of love, play on. But make sure you use this super little DAC to get the best out of your Raspberry Pi audio! This pHAT provides a super affordable high-quality DAC for your Raspberry Pi. It pumps out 24-bits at 192KHz from the Raspberry Pi's I2S interface on its 2x20 pin GPIO header. Use pHAT DAC to build a tiny, lush-sounding streaming music device, or use it with Scroll pHAT to make a beautiful spectrum analyser! Features       24‐bit audio at 192KHz  Line out stereo jack  Optional landing for dual RCA phono connector  PCM5102A DAC over the Raspberry Pi's I2S interface  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W  Female header requires soldering   Software pHAT DAC doesn't require a Python library like most of our other HATs and pHATs, but does require configuration to work properly. We've put together a slick one-line installer to get everything set up just right. See the tutorial below for more details. Notes The kit has a 3.5mm stereo jack pre-assembled but doesn't include a dual RCA phono connector. If you need one then grab it here.        https://shop.pimoroni.com/products/phat‐dac 4/19/2017
PIM138 价格&库存
很抱歉,暂时无法提供与“PIM138”相匹配的价格&库存,您可以联系我们找货
PIM138
  • 11+121.3056611+15.75699
