Page 1 of 2
AudioAmp click
From MikroElektonika Documentation
AudioAmp click functions as a mono audio amplifier. It is driven by a Texas Instruments LM48100QQ1 Boomer™ Mono, 1.3W Audio Power Amplifier IC.
AudioAmp click
Features and usage notes
AudioAmp click has one 3.5 mm input jack and next
to it screw terminals for connecting output wires to a
passive speaker. It has dual audio inputs that can be
mixed/multiplexed to the device output. Each input
path has its own independent, 32-step volume
control. The mixer, volume control and device mode
selection are controlled through the mikroBUS™
I2C interface.
Fault detection is another important feature of
LM48100Q. It senses the load conditions, protecting
the device during short circuit events, as well as
Schematic also available in PDF (http://cdndocs.mikroe.com/images/0/0d/AudioAmp_click_sche detecting open circuit conditions. AudioAmp click
can work either on a 3.3V or a 5V power supply.
There’s an additional jumper for selecting the I2C
address as well. The open-drain output fault flag. FAULT is routed through the default mikroBUS™
INT pin (0 indicates that a fault condition has occurred). Here’s a comprehensive list of LM48100Q’s
key features, taken from the official data sheet:
Output Fault Detection
I2C Volume and Mode Control
Input Mixer and Multiplexer
High PSRR
Individual 32-Step Volume Control
Short Circuit and Thermal Protection
Advanced Click-and-Pop Suppression
Low-Power Shutdown Mode
Available in 14-Pin HTSSOP Package
Key Specifications:
◾ OutputPower at VDD =5V, RL =8Ω, THD+N ≤ 1% 1.3 W (Typical)
◾ Quiescent Power Supply Current at 5 V, 6 mA (Typical)
◾ PSRR at 1 kHz 74 dB (Typical)
◾ Shutdown current 0.01 μA (Typical)
AudioAmp click
IC/Module KN48100Q-Q1
(http://www.ti.com/product/LM48100Q-Q1)
Interface
I2C
Power
3.3V, 5V
supply
Website
www.mikroe.com/click/audio-amp
(http://www.mikroe.com/click/audio-amp)
Programming
The following code snippet demonstrates the click’s power on procedure
1 void power_on()
2 {
I2C2_Start();
3
I2C2_Write( dev_addr );
4
I2C2_Write( POWER_ON );
5
I2C2_Stop();
6
7 }
Code examples that demonstrate the usage of AudioAmp click with MikroElektronika hardware, written for mikroC for AVR, dsPIC, PIC and PIC32 are
available on Libstock (http://libstock.mikroe.com/projects/view/1871/audioamp-click).
Resources
- Libstock example (http://libstock.mikroe.com/projects/view/1871/audioamp-click)
- LM48100Q-Q vendor's data sheet (http://www.ti.com/product/LM48100Q-Q1)
- mikroBUS™ specifications (http://www.mikroe.com/downloads/get/1737/mikrobus_specification.pdf)
Retrieved from "http://docs.mikroe.com/index.php?title=AudioAmp_click&oldid=542"
Page 2 of 2
◾ This page was last modified on 25 July 2016, at 16:56.
◾ Content is available under Creative Commons Attribution unless otherwise noted.
http://docs.mikroe.com/index.php?title=AudioAmp_click&printable=yes
8/8/2016
很抱歉,暂时无法提供与“MIKROE-2368”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+135.76520
- 5+133.04719
- 国内价格 香港价格
- 1+149.852381+19.38741
