Adafruit Joy Bonnet for Raspberry Pi
Created by Phillip Burgess
https://learn.adafruit.com/adafruit-joy-bonnet-for-raspberry-pi
Last updated on 2021-11-15 06:53:40 PM EST
©Adafruit Industries
Page 1 of 9
Table of Contents
Overview
3
Install & Use
6
• Software
• Install!
• Advanced Usage
6
6
8
Downloads
8
• Source Code
• Files
• Schematic
8
8
9
Page 2 of 9
Overview
Pocket-sized fun is the name of this game, with the Joy Bonnet - our most fun Bonnet
ever (no we didn't even think that was possible, either!) This Bonnet fits perfectly on
top of your Raspberry Pi Zero (any kind) and gives you adorable hand-held arcade
controls. Once you install our script onto your Pi, the controls will act like a keyboard,
for easy use with any emulator or media player.
Personally, we found this Bonnet to work best with RetroPie/EmulationStation. On a Pi
Zero we could emulate NES and MAME game (our favorites!) but other emulators that
Page 3 of 9
don't require more than 1GHz speeds will work OK too, e.g. a N64 emulator won't
work, it needs way more power!
Best of all, this Bonnet is fully assembled - no soldering at all is required. You may
need to solder headers onto your Pi Zero (or use press-fit headers) but once that's
done you're ready to rock. In theory you could also use this with a Pi A+ or B+/2/3 but
it wouldn't be very hand-held
Since you'll likely grip the Pi during play, we strongly recommend a comfortable
enclosure to go along with it! The Adafruit Pi Zero case works well and is nice and
rounded for easy holding
Page 4 of 9
Adafruit Raspberry Pi Zero Case
This is a basic, classic Pi Zero enclosure
with a black base and a clear top. The
case is as minimal as it gets, coming in
just two pieces of polycarbonate that...
https://www.adafruit.com/product/3252
Friendly forum-member cvadillo
suggests (https://adafru.it/fEw) slipping
the extra piece of plastic underneath the
bonnet to support it
A Mini HDMI cable will also make it easy to plug-and-play into your HDMI screen
Mini HDMI to HDMI Cable - 5 feet
Connect a device with a Mini HDMI port to
a regular sized HDMI port together with
this basic HDMI cable. It has nice molded
grips for easy installation, and is 1.5 meter
long...
https://www.adafruit.com/product/2775
Page 5 of 9
Install & Use
Software
Software installation for the Joy Bonnet requires an internet connection. That’s a
frequent topic already covered in other Pi getting-started guides, so we’ll assume
here that your Pi is already booted and networked, running Raspbian or a gamingready OS like RetroPie. (RetroPie is what we use, and recommend!) RetroPie has a
nice First Installation guide (https://adafru.it/vbB)
You can set up the controls however you like, its easy to change them up later. Just
get logged into RetroPie, and setup WiFi. Then get into a terminal either on the HDMI
console or by ssh'ing in.
You may find this easiest if ssh is enabled on the Pi, and then log in with a terminal
app. (https://adafru.it/vbC)This lets you copy-and-paste the commands that follow, as
they’re very exact about spelling.
Install!
Enter the following few lines to install support for the buttons and joystick:
cd ~
sudo apt-get install python3-pip
sudo pip3 install --upgrade adafruit-python-shell
wget https://raw.githubusercontent.com/adafruit/Raspberry-Pi-Installer-Scripts/
master/joy-bonnet.py
sudo python3 joy-bonnet.py
When run, this script will offer a couple of options:
• Disable overscan? If you answer “Y” this removes the black border around the
screen (common on HDMI monitors). Takes effect on next boot.
• Install gpio-halt utility? Linux-based systems like the Raspberry Pi don’t like it
when you just switch off power…there’s a specific shutdown process, else the
SD card may get corrupted. The gpio-halt tool lets you add one more button
between ground and any unused GPIO pin to initiate an orderly shutdown.
Gaming OSes like RetroPie already include a shutdown command among their
menu options, so you probably do not need this, unless you want a dedicated
button for it.
Page 6 of 9
When the script finishes you’ll be asked whether to reboot. Answer “N” if you plan on
installing other software. Either way, sudo reboot when done to get the joy bonnet
software activated!
That's it! The script to generate keycodes is now installed and will be run every time
the Pi boots
Once RetroPie has restarted, go to the MENU and step down to CONFIGURE INPUT
and select it to re-start the input configuration. The left joystick can be used for up/
down/left/right. The right buttons are A B X Y. Middle buttons are Select and Start as
labeled. Then you get two more buttons you can set up as left/right shoulder or
trigger buttons.
Note that pressing Select+Start will quit out of games, other than that the controls are
used in the emulators by generating 'key presses' - see below for how to change the
keypresses!
Page 7 of 9
Advanced Usage
If you need to change the key assignments: edit the file /boot/joyBonnet.py say
with sudo nano /boot/joyBonnet.py
Near the top of the code you’ll see this table:
'#' lines are human comments and do nothing for the code. The first eight actual
elements in the table correspond to the button inputs, while the last four are the
joystick directions.
Downloads
Source Code
• Joy Bonnet installer (https://adafru.it/uza) and key-press python script (https://
adafru.it/cbI) available on github!
Files
• EagleCAD PCB files on GitHub (https://adafru.it/vbE)
Page 8 of 9
Schematic
Page 9 of 9
很抱歉,暂时无法提供与“3464”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+142.016471+17.80914
