PIM058
PIM058
    PIMORONI
    SKYWRITERHAT(INDIVIDUAL)
PIM058 数据手册
  Skywriter HAT PIM058 Use this 3D interface to sense things floating in the air over it. Detect swipes and the motion of your hand with X, Y and Z positions. Skywriter HAT uses electrical near-field 3D sensing to generate positional data and detect common gestures like flicks and taps. Use it to control your presentations like a Jedi, make a theremin to amaze and annoy all, or make a lock controlled by a magic spell! Features         Electrical near‐field 3D/gesture sensing  4‐layer PCB for best sensing performance  Range of up to 5cm  Full 3D position data and gesture information (flicks, taps)  Uses the Microchip MGC3130 sensor  Compatible with Raspberry Pi 3, 2, B+, A+, Zero, and Zero W  Python library  Comes fully assembled  Software We've put together a Skywriter HAT Python library to take all the hard work out of reading Skywriter HAT's positional data and gestures, along with some examples to help you get started. Notes Because the sensing distance is up to 5cm you can mount Skywriter HAT behind a sheet of nonconductive material (like acrylic or fabric) and completely hide it inside your project!        https://shop.pimoroni.com/products/skywriter‐hat 4/19/2017
PIM058 价格&库存
很抱歉,暂时无法提供与“PIM058”相匹配的价格&库存,您可以联系我们找货
PIM058
  • 7+201.926857+26.24091
