MIKROE-2378
MIKROE-2378
    MIKRO
    UV2CLICK
MIKROE-2378 数据手册
Page 1 of 2 UV 2 click From MikroElektonika Documentation UVA 2 click carries a VEML6075 UVA and UVB light sensor. VEML6075 is a CMOS chip that incorporates a photodiode, amplifiers, and analog/digital circuits into a single chip. UV 2 click Features and usage notes With UV 2 click, Solar ultraviolet light intensity is converted to 16-bit digital values. To keep a stable output in changing temperature conditions, the chip has temperature compensation capabilities. This ensures reliable performance under long term UV exposure. Schematic also available in PDF (http://cdndocs.mikroe.com/images/f/ff/UV_2_click_schematic_ The sensor has a specified UVA sensitivity of 365 nm and UVB sensitivity of 315 nm). Measurement results are stored in four separate registers. The last result read will remain in the register until a new measurement is loaded. In addition to UVA and UVB it has UVD (a dummy channel for dark current cancellation), UVcomp1, and UVcomp2. All registers are accessible via I2C communication. The board communicates with the target MCU through the mikroBUS™ I2C interface. Both standard (100 kHz) and fast (400 kHz) I2C is supported. Designed to use a 3.3 power supply only. The chip vendor provides a separate Application Note sheet with detailed specifications on how to derive UV radiation values from the sensor readings. For reference, here we provide an explanation of UVA and UVB, taken from the Application Note sheet: UV 2 click IC/Module VEML6075 (http://www.vishay.com/docs/84304/veml6075.pdf) Interface I2C Power 3.3V supply Website www.mikroe.com/click/uv-2 (http://www.mikroe.com/click/uv-2) The UVB rays - wavelengths ranging from 280 nm to 320 nm - are extremely energetic and harmful for the skin to the extent that they are responsible for 65 % of skin tumors. Thankfully, only 0.1 % of the solar energy that arrives on the earth’s surface is in the shape of UVB radiation. The UVA rays - wavelengths ranging from 320 nm to 400 nm - are less powerful than the previous ones, but highly penetrating. They are capable of reaching the skin, becoming responsible for photoaging and promoting the onset of different forms of skin cancer. 4.9 % of the solar energy is made up of UVA rays. Programming Code starts up the UV 2 click, reads the UV index and prints it out on the TFT board. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 #include #include "resources.h" uint8_t uv2_get_8bit(uint8_t reg) { uint8_t tempreg = reg; uint8_t temp = 0; I2C1_Start(); I2C1_Write(0x10, &tempreg,1,END_MODE_RESTART); I2C1_Read(0x10,&temp,1, END_MODE_STOP); } uint16_t uv2_get_16bit (uint8_t reg) { uint8_t temp[2] = {0}; uint16_t retval = 0; uint8_t tempreg = reg; I2C1_Start(); I2C1_Write(0x10, &tempreg,1,END_MODE_RESTART); I2C1_Read(0x10,temp,2, END_MODE_STOP); retval = (uint16_t) temp[0]; retval |= ((uint16_t) temp[1])
MIKROE-2378 价格&库存
很抱歉,暂时无法提供与“MIKROE-2378”相匹配的价格&库存,您可以联系我们找货
