MIKROE-2332
MIKROE-2332
    MIKRO
    DIGIPOT2CLICK
MIKROE-2332 数据手册
Page 1 of 2 DIGI POT 2 click From MikroElektonika Documentation DIGI POT 2 click is a mikroBUS™ add-on board with a single channel digital potentiometer TPL0501 with 256 wiper positions. The IC has 100 kilo Ohms end-to-end resistance, with ±20% tolerance. The board features two pairs of screw terminals for interfacing with the IC DIGI POT 2 click communicates with the target MCU through the mikroBUS™ SPI pins (MISO, MOSI, SCK, CS). The board is designed to use either a 3.3 or a 5V power supply. DIGI POT 2 click Features and usage notes Digital potentiometers are mixed signal devices intended as replacements for mechanical potentiometers. They can be used for consumer electronics, adjustable power supplies, precision calibration and sensor trimming. The device has three terminals: High termianl, low terminal and a wiper terminal which is in-between. The wiper terminal is adjusted through SPI, moving through the specified 256 steps. Schematic also available in PDF (http://cdndocs.mikroe.com/images/e/ea/DIGI_POT_2_click_sc ◾ ◾ ◾ Rheostat mode B DIGI POT click can operate in several configurations: Voltage Divider mode Rheostat mode A More details on each one can be found in the TPL0501 data sheet. Digital potentiomenters can be have any kind of interface. Not just knobs like mechanical potentiometers, but also buttons, capacitive inputs etc). Another advantage of digital potentiometers is that you can create any desirable sweep profile (linear, digital or any other function). DIGI POT 2 click IC/Module Texas Instruments TPL0501 (http://www.ti.com/lit/ds/symlink/tpl0501100.pdf) Interface SPI (MISO, MOSI, SCK, CS) Power supply 3.3V, 5V Website www.mikroe.com/click/digipot-2 (http://www.mikroe.com/click/digipot-2) The operating temperature of TPL0501 is between -40ºC to 125ºC. ESD performance is tested per JESD 22 requirements (human body model). DIGI POT 2 click can be used both with a 3.3V or a 5V power supply, as determined by the position of the onboard jumper (soldered to 3.3V position by default). Programming The following code snippet shows a larger part of the DIGI POT 2 click example we supply: 1 void main() { 2 3 Delay_ms(100); 4 5 while (1) { // Endless loop 6 7 DigPot_CS = 0; // Select PotentioMeter chip 8 SPI1_Write(0); 9 SPI1_Write(counter); 10 SPI1_Write(0x20); 11 SPI1_Write(counter); 12 DigPot_CS = 1; // Deselect PotentioMeter chip 13 14 adc_value = ADC_Read(1); // Get 10-bit results of AD conversion 15 PORTD = (unsigned char)(adc_value >> 2); 16 17 if (PINB2_bit) // Press PB2 to decrease resistance between W and L 18 counter ++; 19 if (PINB3_bit) // Press PB3 to increase resistance between W and L 20 counter --; 21 22 Delay_ms(50); // Delay for debouncing 23 24 } 25 26 } Code examples that demonstrate the usage of DIGI POT 2 click with MikroElektronika hardware, written for mikroC for are available on Libstock (http://libstock.mikroe.com/projects/view/1825/digi-pot-2-click). Page 2 of 2 Resources - Texas Instruments TPL0501 (http://www.ti.com/lit/ds/symlink/tpl0501-100.pdf) Vendor’s data sheet] - DIGI POT 2 click (http://libstock.mikroe.com/projects/view/1825/digi-pot-2-click) - mikroBUS™ standard specifications (http://www.mikroe.com/downloads/get/1737/mikrobus_specification.pdf) Retrieved from "http://docs.mikroe.com/index.php?title=DIGI_POT_2_click&oldid=450" ◾ This page was last modified on 23 June 2016, at 22:10. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=DIGI_POT_2_click&printable=yes 7/11/2016
MIKROE-2332 价格&库存
很抱歉,暂时无法提供与“MIKROE-2332”相匹配的价格&库存,您可以联系我们找货
MIKROE-2332
  • 1+175.808071+22.82781
