DC MOTOR 3 click
1
DC MOTOR 3 click
DC MOTOR 3 click
DC MOTOR 3 click
IC/Module
Interface
Power supply
Website
TB6549FG
[1]
PWM, IN1, IN2, SLP
3.3V
www.mikroe.com/click/dc-motor-3
[2]
DC Motor 3 click is a mikroBUS™ add-on board with a Toshiba TB6549FG full-bridge driver for direct current
motors. The IC is capable of outputting currents of up to 4.5 A with 30V, making it suitable for high-power motors.
Features and usage notes
Two pairs of screw terminals are positioned on the top of the board.
One is for bringing an external power supply; the other is for
connecting a motor.
TB6549FG has four operating modes: clockwise, counter-clockwise,
short brake and stop. The operating mode is configured through IN1
and IN2 pins. A separately controlled standby mode is also available.
Schematic also available in PDF
[3]
For safety, the TB6549FG IC incorporates overcurrent protection and a
thermal shutdown circuit.
The click communicates with the target MCU through the
mikroBUS™ PWM pin, with additional functionality provided by IN1, IN2 and SLP pins (in place of default
mikroBUS™ AN, RST and CS pins). Designed to use a 3.3 power supply only.
Summary of TB6549FG specifications:
Power supply voltage: 30 V (max)
Output current: 3.5 A (max) (FG,PG type)
Low ON-resistance: 1.0 Ω (up + low/typ.)
PWM control capability
DC MOTOR 3 click
2
Standby system
Function modes: CW/CCW/short brake/stop
Built-in overcurrent protection
Built-in thermal shutdown circuit
Programming
This example shows how to setup the DC Motor 3 on ARM, and use buttons to turn the motor, as well as speed up or
slow down the motor.
#include "dc_motor3.h"
unsigned int current_duty;
unsigned int pwm_period;
sbit SLP at GPIOD_ODR.B14;
sbit IN2 at GPIOC_ODR.B3;
sbit IN1 at GPIOA_ODR.B5;
void main()
GPIO_Digital_Input (&GPIOE_BASE, _GPIO_PINMASK_8 | _GPIO_PINMASK_9 |
_GPIO_PINMASK_10 | _GPIO_PINMASK_11 | _GPIO_PINMASK_12); // configure
PORTE pins as input
GPIO_Digital_Output (&GPIOD_BASE, _GPIO_PINMASK_14 );
GPIO_Digital_Output (&GPIOC_BASE, _GPIO_PINMASK_3 );
GPIO_Digital_Output (&GPIOA_BASE, _GPIO_PINMASK_5 );
current_duty = 40000;
current_duty
pwm_period = PWM_TIM4_Init(5000);
// initial value for
PWM_TIM4_Set_Duty(current_duty, _PWM_NON_INVERTED, _PWM_CHANNEL1);
// Set current duty for PWM_TIM1
PWM_TIM4_Start(_PWM_CHANNEL1, &_GPIO_MODULE_TIM4_CH1_PD12);
while(1)
if (Button(&GPIOE_IDR, 8, 50, 1))
dc_motor3_clockwise();
if (Button(&GPIOE_IDR, 9, 50, 1))
DC MOTOR 3 click
3
dc_motor3_counter_clockwise();
if (Button(&GPIOE_IDR, 10, 50, 1))
Delay_ms(1);
current_duty *= 2;
_PWM_NON_INVERTED,
_PWM_CHANNEL1);
if (Button(&GPIOE_IDR, 11, 50, 1))
Delay_ms(1);
current_duty /= 2;
_PWM_CHANNEL1);
_PWM_NON_INVERTED,
if (Button(&GPIOE_IDR, 12, 50, 1))
dc_motor3_stop();
Delay_ms(1);
Code examples for DC MOTOR 3 click are available for ARM and AVR compilers. Download them from Libstock
[4]
Resources
- DC Motor 3 click Libstock example [4]
- Vendor’s data sheet [1]
- mikroBUS™ standard specifications [5]
References
[1]
[2]
[3]
[4]
[5]
http:/ / toshiba. semicon-storage. com/ ap-en/ product/ linear/ motordriver/ detail. TB6549FG. html
http:/ / www. mikroe. com/ click/ dc-motor-3
http:/ / cdn-docs. mikroe. com/ images/ 9/ 98/ Dc-motor-3-click-schematic. pdf
http:/ / libstock. mikroe. com/ projects/ view/ 1904/ dc-motor-3-click
http:/ / download. mikroe. com/ documents/ standards/ mikrobus/ mikrobus-standard-specification-v200. pdf
Article Sources and Contributors
DC MOTOR 3 click Source: http://docs.mikroe.com/index.php?oldid=743 Contributors: Srdjan.misic
Image Sources, Licenses and Contributors
File:DC MOTOR 3 click.jpg Source: http://docs.mikroe.com/index.php?title=File:DC_MOTOR_3_click.jpg License: unknown Contributors: Srdjan.misic
File:Dc-motor-3-click-schematic.png Source: http://docs.mikroe.com/index.php?title=File:Dc-motor-3-click-schematic.png License: unknown Contributors: Srdjan.misic
License
Creative Commons Attribution
https:/ / creativecommons. org/ licenses/ by/ 4. 0/
4
很抱歉,暂时无法提供与“MIKROE-2047”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+183.66885
- 5+180.00318
