MIKROE-2239
MIKROE-2239
    MIKRO
    MATRIXRGBCLICK
MIKROE-2239 数据手册
Matrix RGB click Matrix RGB click is a mikroBUS™ add-on board powered by a 32-bit FT900 MCU designed specifically for powering 16x32 RGB LED matrices. The board has a 16 wire IDC connector for connecting to a single 16x32 LED panel; however, the firmware inside the FT900x chip can drive more than one panel. Multiple panels can be connected to each other into a daisy-chain configuration (see the video). Matrix RGB click communicates with the target MCU through the SPI interface. It uses a 3.3V power supply only. Complete ​kits with Matrix RGB click, a single 32x32 RGB LED matrix panel (consisting of two 16x32 matrices joined together), and a power supply unit are available to order. Alternatively, panels and power supplies can be purchased separately. Technical Specifications Applications Driving up to 16 16x32 RGB LED panels (more than 32 is possible, but flickering may occurr). Key features Can drive up to 16 panels of 16x32 RGB LEDs Removes the load from the host MCU Microcontroller can be accessed through separate IDC connector Ready-to-use examples save development time Don't forget However powerful, Matrix RGB click is only a driver board, and you need to have one or more RGB panels and a power adapter to see the output. Make sure you add them to your cart along side with the click. MIKROE-2239 Matrix RGB click Copyright © 1998 - 2016. MikroElektronika d.o.o.
MIKROE-2239 价格&库存
很抱歉,暂时无法提供与“MIKROE-2239”相匹配的价格&库存,您可以联系我们找货
