DEV-14037
DEV-14037
    SPARKFUNELECTRONICS
    PIMORONIUNICORNHAT
DEV-14037 数据手册
Pimoroni Unicorn HAT DEV-14037 Description: The Pimoroni Unicorn HAT is a “shield” for the Raspberry Pi that sports a matrix of 64 (8x8) addressable RGB LEDs that are powered directly from the Pi. The Unicorn HAT provides a wash of controllable color that is ideal for mood lighting, 8x8 pixel art, persistence of vision effects, status indications, or just blasting color into your surroundings. Each Pimoroni Unicorn Hat easily snaps on top of a Raspberry Pi equipped with a 40-pin (2x20) GPIO. Pimoroni has created a GitHub repository bundling the Unicorn Hat software with a set of examples to get you started in an easy-to-use Python module, so all you have to worry about is setting the color you want each pixel to be. Features: 64 RGB LEDs (WS2812B) Python API Compatible with Raspberry Pi 3, 2, B+, and A+ EEPROM with Raspberry Pi HAT configuration details LED data driven via DMA over PWM SparkFun Electronics ®
DEV-14037 价格&库存
很抱歉,暂时无法提供与“DEV-14037”相匹配的价格&库存,您可以联系我们找货
