PIM062
PIM062
    PIMORONI
    SKYWRITER
PIM062 数据手册
    Skywriter: 3D Gesture Sensing Breakout PIM062   The big brother to the Skywriter HAT - Skywriter adds 3D gesture sensing to your project! Using our Python and Arduino libraries you can read off the positional data (x, y, z) and common gestures like flick left, tap, and double tap.         Electrical near‐field 3D/gesture sensing  Senses from up to 10cm away!  Full 3D position data and gesture information (swipes, taps)  3V3 or 5V compatible, all signals level shifted  Comes with 4 non‐slip rubber feet and strip header to solder yourself  Dimensions 94mm x 122mm  Mounting holes!  Full Python (for Raspberry Pi) and Arduino libraries!  Because the sensing distance is up to 10cm you can mount your Skywriter behind a sheet of non conductive material (like acrylic or fabrics) and completely hide it inside your project. features      3V3 and 5V compatible   Level‐shifted logic   15cm range   X/Y/Z 3D position sensing   Gesture recognition        https://shop.pimoroni.com/products/skywriter 4/19/2017
PIM062 价格&库存
很抱歉,暂时无法提供与“PIM062”相匹配的价格&库存,您可以联系我们找货
