PIM117
PIM117
    PIMORONI
    HDMI8"LCDSCREENKIT(800X600)
PIM117 数据手册
CHIMEI INNOLUX DISPLAY CORPORATION LCD MODULE S P E C I F I C AT I O N Customer: Model Name: EJ080NA-05B Date: 2011/04/28 Version: 01 ■ Preliminary Specification □ Final Specification For Customer ’s Acceptance Approved by Comment Approved by Review ed by Prepared by Hans Chen James Yu Charlie Chou David Lee 2011/05/10 2011/05/09 2011/04/28 Free Datasheet http://www.Datasheet4U.com 6InnoLux copyright 2004 All rights reserved, Copying forbidden. Record of Revision Version Pre-Spec.01 Revise Date 2011/04/09 Page Content Initial Release. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Contents 1. General Specifications ............................................................................................................ 1 2. Pin Assignment....................................................................................................................... 2 2.1. TFT LCD Panel Driving Section...................................................................................... 2 3. Operation Specifications ......................................................................................................... 5 3.1. Absolute Maximum Rating.............................................................................................. 5 3.1.1. Typical Operation Conditions.................................................................................. 6 3.1.2. Current Consumption ............................................................................................. 7 3.1.3. Backlight Driving Conditions ................................................................................... 7 3.2. Power Sequence ............................................................................................................ 8 3.3. Timing Characteristics .................................................................................................... 9 3.3.1. AC Electrical Characteristics .................................................................................. 9 3.3.2. Timing................................................................................................................... 10 3.3.3. Timing Diagram .................................................................................................... 11 4. Optical Specifications............................................................................................................ 12 5. Reliability Test Items ............................................................................................................. 16 6. General Precautions ............................................................................................................. 17 6.1. Safety ........................................................................................................................... 17 6.2. Handling ....................................................................................................................... 17 6.3. Static Electricity ............................................................................................................ 17 6.4. Storage ......................................................................................................................... 17 6.5. Cleaning ....................................................................................................................... 17 7. Mechanical Drawing ............................................................................................................. 18 8. Package Drawing ................................................................................................................... 19 8.1 Packaging Material Table.............................................................................................. 19 8.2 Packaging Quantity ...................................................................................................... 19 8.3 Packaging Drawing....................................................................................................... 20 Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:1/20 1. General Specifications No. Item Specification 1 LCD size 8.0 inch(Diagonal) 2 Driver element a-Si TFT active matrix 3 Resolution 800 × 3(RGB) × 600 4 Display mode Normally White, Transmissive 5 Dot pitch 0.0675(W) × 0.2025(H) mm 6 Active area 162.0(W) × 121.5(H) mm 7 Module size 183.0(W) × 141.0(H) × 5.6(D) mm 8 Surface treatment Anti-Glare 9 Color arrangement RGB-stripe 10 Interface Digital 11 Backlight power consumption 1.782W (Typ.) 12 Panel power consumption 0.356W(Typ.) 13 Weight TBD Remark Note 1 Note 1: Refer to Mechanical Drawing. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:2/20 2. Pin Assignment 2.1. TFT LCD Panel Driving Section 1. FPC Connector is used for the module electronics interface. The recommended model is FH12A-50S-0.5SH manufactured by Hirose. Pin No. Symbol I/O Function Remark P 1 LED + LED Anode 2 LED + P LED Anode 3 LED - P LED Cathode 4 LED - P LED Cathode 5 GND P Power ground 6 VCOM I Common voltage 7 8 VCC MODE P I Power for Digital circuit DE/SYNC mode select 9 DE I Data Input Enable 10 VS I Vertical Sync Input 11 HS I Horizontal Sync Input 12 B7 I Blue data(MSB) 13 14 B6 B5 I I Blue data Blue data 15 B4 I Blue data 16 B3 I Blue data 17 B2 I Blue data 18 B1 I Blue data 19 20 B0 G7 I I Blue data(LSB) Green data (MSB) 21 G6 I Green data 22 G5 I Green data 23 G4 I Green data 24 G3 I Green data 25 26 G2 G1 I I Green data Green data 27 G0 I Green data (LSB) 28 R7 I Red data (MSB) 29 R6 I Red data 30 R5 I Red data 31 R4 I Red data Note3 Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:3/20 32 R3 I Red data 33 R2 I Red data 34 35 R1 R0 I I Red data Red data (LSB) 36 GND P Power ground 37 DCLK I Sample clock 38 GND P Power ground 39 L/R I Right/ left selection Note2,5 40 41 U/D VGH I P Up/down selection Gate ON voltage Note2,5 42 VGL P Gate OFF voltage 43 AVDD P Power for Analog circuit 44 RESET I Global reset pin. 45 NC - No connection 46 47 VCOM DITHB I I Common voltage Dithering function 48 GND P Power ground 49 NC - No connection Note1 Note 4 50 NC No connection I: input, O: output, P: Power Note 1: Global reset pin. Active Low to enter Reset State. Suggest to connecting with an RC reset circuit for stability. Normally pull high. Note 2: Selection of scanning mode Setting of scan control input Scanning direction U/D R/L GND VCC Up to down, left to right VCC GND Down to up, right to left GND GND Up to down, right to left VCC VCC Down to up, left to right Note 3: DE/SYNC mode select, Normally pull high. H: DE mode. L: HS/VS mode. Note4: Dithering function enable control. Normally pull high. DITHB=”1”,Disable internal dithering function. For 18bit RGB interface, connect two LSB bits of all the R/G/B data buses to GND. DITHB=”0”,Enable internal dithering function, For TTL 24bit parallel RGB image data input. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:4/20 Note 5: Definition of scanning direction. Refer to the figure as below: Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:5/20 3. Operation Specifications 3.1. Absolute Maximum Rating (GND=AVSS=0V, Note 1) Values Item Symbol Unit Min. Max. VCC -0.3 5.0 V AVDD -0.5 13.5 V VGH 13.0 19.0 V VGL -12.0 -2.0 V VGH-VGL - 31.0 V TOP -20 70 ℃ TST -30 80 ℃ LED Reverse Voltage VR - 1.2 V LED Forward Current IF - 25 mA Power voltage Operation Temperature Storage Temperature Remark each LED Note 2 each LED Note 1: The absolute maximum rating values of this product are not allowed to be exceeded at any times. Should a module be used with any of the absolute maximum ratings exceeded, the characteristics of the module may not be recovered, or in an extreme case, the module may be permanently destroyed. Note 2: VR Conditions: Zener Diode 20mA Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX 3.1.1. Date :2011/04/28 Page:6/20 Typical Operation Conditions (GND=AVSS=0V, Note 1) Values Item Symbol Unit Remark Note 2 Min. Typ. Max. VCC 3.0 3.3 3.6 V AVDD 10.2 10.4 10.6 V VGH 15.3 16.0 16.7 V VGL -7.7 -7.0 -6.3 V VCOM 2.8 (3.8) 4.8 V Input logic high voltage VIH 0.7VCC - VCC V Input logic low voltage VIL 0 - 0.3VCC V Power voltage Input signal voltage Note 4 Note 3 Note 1: Be sure to apply VCC and VGL to the LCD first, and then apply VGH. Note 2: VCC setting should match the signals output voltage (refer to Note 3) of customer’s system board . Note 3: DCLK,HS,VS,RSTB,UPDN,STLR,MODE,DITHB. Note 4: Typical VCOM is only a reference value, it must be optimized according to each LCM. Be sure to use VR; Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX 3.1.2. Date :2011/04/28 Page:7/20 Current Consumption (GND=AVSS=0V) Values Item Symbol Unit Remark Min. Typ. Max. IGH - 0.2 0.5 mA VGH =16.0V IGL - 0.2 1.0 mA VGL = -7.0V ICC - 5.5 10.0 mA VCC =3.3V IAVDD - 32.0 50.0 mA AVDD =10.4V Current for Driver 3.1.3. Backlight Driving Conditions Values Item Symbol Min. Typ. Max. Unit Remark Note 1 Voltage for LED backlight VL 9.3 9.9 10.5 V Current for LED backlight IL 162 180 198 mA LED life time - 20,000 - - Hr Note 2 Note 1: The LED Supply Voltage is defined by the number of LED at Ta=25℃ and IL =180mA. Note 2: The “LED life time” is defined as the module brightness decrease to 50% original brightness at Ta=25℃ and IL =180mA. The LED lifetime could be decreased if operating IL is lager than 180 mA. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:8/20 3.2. Power Sequence 3.2.1. Power on: VCC→ →VGL→ →AVDD→ →VGH→ →Data→ →B/L 3.2.2. Power off: B/L→ →Data→ →VGH→ →AVDD→ →VGL→ →VCC Note: Data include R0~R5, B0~B5, GO~G5, STLR,UPDN, DCLK, HS,VS,DE. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX 3.3. Date :2011/04/28 Page:9/20 Timing Characteristics 3.3.1. AC Electrical Characteristics Values Item Symbol Unit Min. Typ. Max. HS setup time Thst 8 - - Ns HS hold time Thhd 8 - - Ns 8 - - Ns VS setup time Tvst VS hold time Tvhd 8 - - Ns Data setup time Tdsu 8 - - Ns Data hole time Tdhd 8 - - Ns DE setup time Tesu 8 - - Ns DE hole time Tehd 8 - - Ns VDD Power On Slew rate TPOR - - 20 ms RSTB pulse width TRst 10 - - us CLKIN cycle time Tcoh 20 - - Ns CLKIN pulse duty Tcwh 40 50 60 % Output stable time Tsst - - 6 us Remark Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX 3.3.2. Date :2011/04/28 Page:10/20 Timing Values Item Symbol Unit Min. Typ. Max. Horizontal Display Area thd - 800 - DCLK DCLK Frequency fclk - 40 50 MHz One Horizontal Line th 862 1056 HS pulse width thpw 1 - 40 DCLK HS Back Porch(Blanking) thb 46 46 46 DCLK HS Front Porch thfp 16 210 354 DCLK Remark 1200 DCLK Values Item Symbol Unit Min. Typ. Max. Vertical Display Area tvd - 600 - TH VS period time tv 624 635 700 TH VS pulse width tvpw 1 - 20 TH VS Back Porch(Blanking) tvb 23 23 23 TH VS Front Porch tvfp 1 12 77 TH Remark Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX 3.3.3. Date :2011/04/28 Page:11/20 Timing Diagram Figure 3.1 Input Clock and Data Timing Diagram Figure 3.2 Horizontal input timing diagram. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:12/20 4. Optical Specifications Values Item Viewing angle (CR≥ 10) Symbol Condition Unit Min. Typ. Max. θL Φ=180°(9 o’clock) 60 70 - θR Φ=0°(3 o’clock) 60 70 - θT Φ=90°(12 o’clock) 40 50 - θB Φ=270°(6 o’clock) 60 70 - TON - 10 TOFF - CR Remark degree Note 1 20 msec Note 3 15 30 msec Note 3 400 500 - - Note 4 0.26 0.31 0.36 - WY 0.28 0.33 0.38 - Note 2 Note 5 Note 6 Luminance L 200 250 - cd/m² Note 6 Luminance uniformity YU 70 75 - % Note 7 Response time Contrast ratio WX Color chromaticity Normal θ=Φ=0° Test Conditions: 1. VCC=3.3V, IL=180mA (Backlight current), the ambient temperature is 25℃. 2. The test systems refer to Note 2. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:13/20 Note 1: Definition of viewing angle range Normal line θ=Φ=0° Φ=90° 12 o’clock direction θR θL θT θB Φ=180° Φ=0° Active Area Φ=270° 6 o’clock direction Fig. 4-1 Definition of viewing angle Note 2: Definition of optical measurement system. The optical characteristics should be measured in dark room. After 30 minutes operation, the optical properties are measured at the center point of the LCD screen. (Response time is measured by Photo detector TOPCON BM-7, other items are measured by BM-5A/Field of view: 1° /Height: 500mm.) Photo detector Normal line θ=Φ=0° Φ=90° 12 o’clock direction 500mm Φ=180° Φ=0° Active Area LCD Panel Φ=270° 6 o’clock direction Fig. 4-2 Optical measurement system setup Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:14/20 Note 3: Definition of Response time The response time is defined as the LCD optical switching time interval between “White” state and “Black” state. Rise time (TON) is the time between photo detector output intensity changed from 90% to 10%. And fall time (TOFF) is the time between photo detector output intensity changed from 10% to 90%. Photo detector output (Relative value) White (TFT OFF) Black (TFT ON) White (TFT OFF) 100% 90% 10% 0% TON TOFF Fig. 4-3 Definition of response time Note 4: Definition of contrast ratio Contrast ratio (CR) = Luminance measured when LCD on the " White" state Luminance measured when LCD on the " Black" state Note 5: Definition of color chromaticity (CIE1931) Color coordinates measured at center point of LCD. Note 6: Definition of luminance: Measured at the center area of the panel when LCD panel is driven at “white” state. The LED driving condition is IL=180mA . Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:15/20 Note 7: Definition of Luminance Uniformity Active area is divided into 9 measuring areas (Refer to Fig. 4-4 ).Every measuring point is placed at the center of each measuring area. Luminance Uniformity (Yu) = L-------Active area length B min B max W----- Active area width L/6 L/3 L/3 W/3 W W/3 W/6 L Fig. 4-4 Definition of measuring points Bmax: The measured maximum luminance of all measurement position. Bmin: The measured minimum luminance of all measurement position. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:16/20 5. Reliability Test Items (Note3) Item Test Conditions Remark High Temperature Storage Ta = 80℃ 240hrs Note 1,Note 4 Low Temperature Storage Ta = -30℃ 240hrs Note 1,Note 4 High Temperature Operation Ts = 70℃ 240hrs Note 2,Note 4 Low Temperature Operation Ta = -20℃ 240hrs Note 1,Note 4 Operate at High Temperature and Humidity +40℃, 90%RH Thermal Shock -30℃/30 min ~ +80℃/30 min for a total 100 cycles, Start with cold temperature and end with high temperature. Vibration Test Frequency range:10~55Hz Stroke:1.5mm Sweep:10Hz~55Hz~10Hz 2 hours for each direction of X. Y. Z. (6 hours for total) Mechanical Shock 100G 6ms,±X, ±Y, ±Z 3 times for each direction Package Vibration Test Random Vibration : 0.015G*G/Hz from 5-200HZ, -6dB/Octave from 200-500HZ 2 hours for each direction of X. Y. Z. (6 hours for total) Package Drop Test Height:60 cm 1 corner, 3 edges, 6 surfaces Electro Static Discharge ± 2KV, 240hrs Note 4 Note 4 Human Body Mode, 100pF/1500Ω Note 1: Ta is the ambient temperature of samples. Note 2: Ts is the temperature of panel’s surface. Note 3: In the standard condition, there shall be no practical problem that may affect the display function. After the reliability test, the product only guarantees operation, but don’t guarantee all of the cosmetic specification. Note 4: Before cosmetic and function test, the product must have enough recovery time, at least 2 hours at room temperature. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:17/20 6. General Precautions 6.1. Safety Liquid crystal is poisonous. Do not put it in your mouth. If liquid crystal touches your skin or clothes, wash it off immediately by using soap and water. 6.2. Handling 1. The LCD panel is plate glass. Do not subject the panel to mechanical shock or to excessive force on its surface. 2. The polarizer attached to the display is easily damaged. Please handle it carefully to avoid scratch or other damages. 3. To avoid contamination on the display surface, do not touch the module surface with bare hands. 4. Keep a space so that the LCD panels do not touch other components. 5. Put cover board such as acrylic board on the surface of LCD panel to protect panel from damages. 6. Transparent electrodes may be disconnected if you use the LCD panel under environmental conditions where the condensation of dew occurs. 7. Do not leave module in direct sunlight to avoid malfunction of the ICs. 6.3. Static Electricity 1. Be sure to ground module before turning on power or operating module. 2. Do not apply voltage which exceeds the absolute maximum rating value. 6.4. Storage 1. Store the module in a dark room where must keep at 25±10℃ and 65%RH or less. 2. Do not store the module in surroundings containing organic solvent or corrosive gas. 3. Store the module in an anti-electrostatic container or bag. 6.5. Cleaning 1. Do not wipe the polarizer with dry cloth. It might cause scratch. 2. Only use a soft sloth with IPA to wipe the polarizer, other chemicals might permanent damage to the polarizer. Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:18/20 7. Mechanical Drawing Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:19/20 8. Package Drawing 8.1 Packaging Material Table No. LCM Module 2 Partition 4 Quantity 183.0 × 141.0 × 5.6 TBD 30pcs 512 × 349 × 226 1.184 1set 349 × 186 × 38 0.155 4pcs PE 700 × 530 0.060 1pcs Item 1 3 Dimensions(mm) Unit Weight (kg) Model (Material) Corrugated Bar Dust-Proof Bag EJ080NA-05B BC Corrugated paper B Corrugated paper 5 A/S Bag PE 220.0 × 200.0 × 0.2 0.003 30pcs 6 Carton Co rru ga t e d pap e r 530 × 355 × 255 1 . 1 00 1 p cs 7 Total weight Remark TBD±5% 8.2 Packaging Quantity Total LCM quantity in Carton: no. of Partition 2 Rows × quantity per Row 15 = 30 Free Datasheet http://www.Datasheet4U.com CHIMEI INNOLUX Date :2011/04/28 Page:20/20 8.3 Packaging Drawing Free Datasheet http://www.Datasheet4U.com
PIM117
物料型号:EJ080NA-05B
器件简介: - 尺寸:8.0英寸对角线 - 驱动元件:a-Si TFT有源矩阵 - 分辨率:800×3(RGB)×600 - 显示模式:通常白色,透射式 - 点距:0.0675(W)×0.2025(H)毫米 - 活动区域:162.0(W)×121.5(H)毫米 - 模块尺寸:183.0(W)×141.0(H)×5.6(D)毫米 - 表面处理:抗眩光 - 颜色排列:RGB条纹 - 接口:数字 - 背光功耗:1.782W(典型值) - 面板功耗:0.356W(典型值)
引脚分配: - FPC连接器用于模块电子接口,推荐型号为Hirose的FH12A-50S-0.5SH。 - 引脚包括LED阳极、阴极、电源地、公共电压、数字电路电源、模式选择、数据输入使能、垂直同步输入、水平同步输入等。
参数特性: - 绝对最大额定值包括电源电压、VGH、VGL、VGH-VGL、操作温度范围、存储温度范围等。 - 典型操作条件包括VCC、AVDD、VGH、VGL、VCOM、VIH、VIL等。
功能详解: - 电源时序、定时特性、光学特性、可靠性测试项目、一般预防措施等。
应用信息: - 该模块适用于需要8英寸LCD显示的应用场合。
封装信息: - 包括机械图纸和包装图纸,详细描述了模块的尺寸、重量和包装材料。
PIM117 价格&库存
很抱歉,暂时无法提供与“PIM117”相匹配的价格&库存,您可以联系我们找货
