MIKROE-2399
MIKROE-2399
    MIKRO
    BTAUDIOCLICK
MIKROE-2399 数据手册
Page 1 of 2 BT Audio click From MikroElektonika Documentation BT Audio click features Microchip’s RN52 Bluetooth audio module capable of streaming high quality audio. The module combines class 2 Bluetooth radio and an embedded DSP processor, controlled and configured by simple ASCII commands and GPIO. The board has two audio jacks, input (microphone) and line out (for connecting speakers). BT Audio click Contents ◾ 1 Features and usage notes ◾ 1.1 1. BT Audio click can stream audio files ◾ 1.2 2. Quality of sound over Bluetooth ◾ 1.3 3. Connectivity to Apple devices ◾ 1.4 4. Bluetooth range ◾ 2 Key features ◾ 3 Pinout diagram ◾ 4 Resources Features and usage notes 1. BT Audio click can stream audio files DSP, or digital signal processor, is what makes this module special, because the module can actually stream audio – it converts and compresses the radio waves sent from your phone or computer into digital data, and then sends it to your speakers or headphones. 2. Quality of sound over Bluetooth BT Audio click IC/Module RN52 (http://ww1.microchip.com/downloads/en/DeviceDoc/70005120A.pdf) Interface UART Power 3.3V supply Product www.mikroe.com/click/bt-audio (http://www.mikroe.com/click/bt- page audio) Schematic BT Audio click schematic (http://cdndocs.mikroe.com/images/b/b0/BT-Audio-click-schematic_v100.pdf) You can be glad to know that the module supports aptX, audio codec for high quality stereo audio streaming over a Bluetooth connection. So the quality of the sound is not something you will have to compromise on, as aptX encodes a CD-quality (16-bit / 44.1kHz) audio stream. 3. Connectivity to Apple devices The module also supports iAP profile discovery for connecting BT Audio click to Apple devices like iPods, iPhones or MAC computers. ◾ The RN52 supports HSP/HFP, A2DP, AVRCP and SPP, as well as digital I/O, stereo speaker output, stereo microphone input,up to 11 General Purpose I/O’s, and 2 LED status outputs. ◾ The HSP/HFP stands for Hands-Free Profile and Headset Profile for an audio connection between Bluetooth on your phone and the headset. 4. Bluetooth range The BT Audio click has a 10m range in open space, but it might be less indoors, because of all the walls and other kinds of barriers. But it is enough range to cover your house or apartment, so you can move your phone to the kitchen without losing the connection to the speakers. BT Audio click communicates with the target board MCU through MikroBUS UART. A green LED indicates that power is on. The BT Audio click runs on 3.3V power supply only. Key features The demo is a GUI application made for the mikromedia+ for STM32F7 with a shield. The Application uses BT Audio library to interface between the touch screen and click board to play music and make phone calls. 1 void play_btnOnClick() 2 { 3 connection_status_t connection; 4 5 bt_audio_query_connection_status( &connection ); 6 if( !connection.A2DP_connection ) 7 return; 8 if( music_state_t == PAUSED ) Page 2 of 2 9 10 11 12 13 14 15 16 17 18 } { } bt_audio_pause_play_track(); music_state_t = PLAYING; if( first_song ) { get_track_data(); first_song = false; } The complete project is available on Libstock (http://libstock.mikroe.com/projects/view/1947/bt-audio-click). Pinout diagram This table shows how the pinout on BT Audio click corresponds to the pinout on the mikroBUS™ socket. Notes Pin Pin Notes mikroBUStm Defines baud rate of module Powers up the module BAUD 1 AN PWM 16 CMD 2 RST INT POWER_EN 3 CS 4 SCK 5 MISO X Puts module in command/data operation 15 FIRST Factory reset TX 14 RX RX 13 TX SCL 12 6 MOSI SDA 11 +3.3V power input +3.3V 7 +3.3V +5V Ground GND 8 GND GND 9 GND 10 NC This click supports 3.3V only Ground Resources ◾ ◾ ◾ ◾ Data sheet (http://ww1.microchip.com/downloads/en/DeviceDoc/70005120A.pdf) BT Audio URL Demo code / Library (http://libstock.mikroe.com/projects/view/1947/bt-audio-click) Learn link Multimedia Station Tutorial (http://learn.mikroe.com/rn52-media-station) mikroBUS™ standard specifications (http://www.mikroe.com/mikrobus/) Retrieved from "http://docs.mikroe.com/index.php?title=BT_Audio_click&oldid=1972" Category: Home page ◾ This page was last modified on 10 November 2016, at 17:45. ◾ Content is available under Creative Commons Attribution unless otherwise noted. http://docs.mikroe.com/index.php?title=BT_Audio_click&printable=yes 12/13/2016
MIKROE-2399 价格&库存
很抱歉,暂时无法提供与“MIKROE-2399”相匹配的价格&库存,您可以联系我们找货
MIKROE-2399
  • 1+518.992941+67.18813
