DEV-10182
DEV-10182
    SPARKFUNELECTRONICS
    VNH2SP30 Motor Control/Driver Power Management Arduino Platform Evaluation Expansion Board
DEV-10182 数据手册
 SparkFun Monster Moto Shield DE V-10 182 RO HS       1  images are CC BY-NC-SA 3.0 Description: This is essentially a ramped up version of our Ardumoto motor driver shield. For this SparkFun Monster Moto Shield we’ve replaced the L298 H-bridge with a pair of VNH2SP30 full-bridge motor drivers. We’ve also beefed up the support circuitry so this board is capable of driving a pair of high-current motors! The VIN and motor out are pitched for our 5mm screw terminals (not included), making it easy to connect larger gauge wires. Note: When using this board in extreme high-demand applications it may be necessary to improve thermal performance with a heat-sink or fan and to solder the wires directly to the board instead of using a screw terminal (in addition to the myriad other complications present in a high-current system) However, when using the board at currents up to 6A the chips will barely become noticeably warm. Features: • • • • • • • • Voltage max: 16V Maximum current rating: 30 A Practical Continuous Current: 14 A Current sensing available to Arduino analog pin MOSFET on-resistance: 19 mΩ (per leg) Maximum PWM frequency: 20 kHz Thermal Shutdown Undervoltage and Overvoltage shutdown https://www.sparkfun.com/products/10182 10/12/2015
DEV-10182 价格&库存
很抱歉,暂时无法提供与“DEV-10182”相匹配的价格&库存,您可以联系我们找货
