Grove - Light Sensor (P) v1.1
SKU 101020173
Linear analog output conforming to illuminance
Low dark current and low working lux
Easy to use
Description
Differs from the last version, the Grove - Light Sensor (P) v1.1 uses the LS06-S phototransistor as a
replacement of the traditional Light Dependent Resistor (LDR) sensors. The LS06-S light sensor has
much more linear analog output conforming to illuminance, which ranges from 0 to the supplying
voltage (normally 5V). A value equals to the supplying voltage can be detected when it’s exposed to
daylight, and it gives 0V when you covered it with your hand.
KEY FEATURES
Easy to use
SPECIFICATIONS
Power supply: 3.3 - 5V DC
Phototransistor: LS06-S
Connector: 4 pin Buckled Grove interface
Dimension: 20mm*20mm
Copyright © 2008-2016 Seeed Development Limited All rights reserved
很抱歉,暂时无法提供与“101020173”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+27.459451+3.54942
