102990205
102990205
    SEEED(矽递科技)
    PHOENARDPHOENONPROTO
102990205 数据手册
Phoenard Phoenon Proto SKU 102990205 DESCRIPTION This Phoenard on-board extension can be connected to the small header on the main board and screwed in with the case. You can then add your own electronic designs to the Phoenard to be carried around with it. Features A 5 x 20 prototyping grid for soldering components to (2.54mm)     A group of SMD component sockets are exposed     Specifications Safe operating conditions         Temperature: -10 ~ 60 degrees celcius             Humidity: 20% - 90%             Power         Main board voltage: 3v3             Accessible pins         Analog: 6 analog pins (A0 - A5)             Digital: 3 general purpose I/O; supports PWM (digital pins 12, 13, 47, shared I/O!)             ISP Interface: 4-pin (MISO/MOSI/SCK//GND)             I2C Interface: SDA/SCL             Power: 3v3 (main board)             Part List 1 x Phoenon Proto PCBA     Note This board uses a 3v3 main board voltage and may not be compatible with all 5v sensors and devices. The 5v power on the extension connector is only present when USB power is provided. A starters guide together with documentation and software examples is available on our website: Getting started     Software documentation     Forums     Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved
102990205 价格&库存
很抱歉,暂时无法提供与“102990205”相匹配的价格&库存,您可以联系我们找货
