3346
3346
    ADAFRUIT
    I2S3WSTEREOSPEAKERAMPBONNET
3346 数据手册
Adafruit Speaker Bonnet for Raspberry Pi Created by lady ada https://learn.adafruit.com/adafruit-speaker-bonnet-for-raspberry-pi Last updated on 2021-11-15 06:50:35 PM EST ©Adafruit Industries Page 1 of 32 Table of Contents Overview 3 Assembly 5 • And Solder! 6 Pinouts 10 • Power Supply • I2S Audio Data Pins • Speaker Outputs 10 12 12 Raspberry Pi Setup 14 • • • • • • 14 16 16 18 18 20 Fast Install Detailed Install Update /etc/modprobe.d (if it exists) Disable headphone audio (if it's set) Create asound.conf file Add Device Tree Overlay Raspberry Pi Test 21 • • • • • 21 21 22 22 22 Speaker Tests! Simple white noise speaker test Simple WAV speaker test Simple MP3 speaker test Volume adjustment Pi I2S Tweaks • Reducing popping • Step 1 • Add software volume control 23 24 24 26 I2S Audio FAQ 28 Play Audio with PyGame 29 • Install PyGame • Run Demo 29 29 Downloads 31 • Datasheets & Files • Schematic • Fabrication Print 31 32 32 ©Adafruit Industries Page 2 of 32 Overview Hey Mr. DJ! Turn up that Raspberry Pi mix to the max with this cute 3W Stereo Amplifier Bonnet for Raspberry Pi. (It's not big enough to be an official HAT, so we called it a bonnet, you see?) It's the exact same size as a Raspberry Pi Zero but works with any and all Raspberry Pi computers with a 2x20 connector - A+, B+, Zero, Pi 2, Pi 3, etc. We've tested it out with Raspbian (the offical operating system) and Retropie. This Bonnet uses I2S a digital sound standard, so you get really crisp audio. The digital data goes right into the amplifier so there's no static like you hear from the ©Adafruit Industries Page 3 of 32 headphone jack. And it's super easy to get started. Just plug in any 4 to 8 ohm speakers, up to 3 Watts, run our installer script on any Raspberry Pi, reboot and you're ready to jam! Each order comes as a fully assembled PCB with a 2x20 header and 2x terminal blocks. Some light soldering is required to attach the header onto PCB so you can plug it into your Raspberry Pi. Once that's done either plug one of our enclosed speaker sets (http://adafru.it/1669) right into the JST jack in the middle or you can solder the terminal blocks in and then connect any speaker you like. Don't forget to make sure you have a good strong 5V power supply - especially if you're using the 3W 4 ohm speakers! Our 2.4A power plug is recommended (http:// adafru.it/1995) ©Adafruit Industries Page 4 of 32 Assembly Place the 2x20 female header in so the connector is on the bottom. To make it easier to keep it in place, you can use some tape. Tacky clay also works, whatever you've got handy! ©Adafruit Industries Page 5 of 32 And Solder!   Be sure to solder all pins for reliable electrical contact. (For tips on soldering, be sure to check out our Guide to Excellent Soldering (https://adafru.it/aTk)). Start by soldering the first row of header ©Adafruit Industries Page 6 of 32 Now flip around and solder the other row completely ©Adafruit Industries Page 7 of 32 You're done with the header strips.   Check your solder joints visually and continue onto the next steps Next we will solder in the 2 3.5mm terminal blocks used to connect speakers to the Speaker Bonnet.    Make sure the open parts of the terminals face outwards so you can easily connect wires.   To make it easier to keep these in place, you can use some tape to hold down the two header pieces. Tacky clay also works, whatever you've got handy! ©Adafruit Industries Page 8 of 32 Solder in each block, make sure you get to each of the 4 pins Now that you're done with the terminal blocks, check your work make sure that each solder joint is done and looks shiny ©Adafruit Industries Page 9 of 32 OK you're done! Pinouts Power Supply The two amplifier chips use the 3V + 5V + GND power pin at the 'top' of the 2x20 header. If using 3W speakers, you can draw a significant amount of current, over 1.5 Amps! Make sure you power your Pi with a good wall adapter like our 2.4A microUSB power plug. ©Adafruit Industries Page 10 of 32 5V 2.5A Switching Power Supply with 20AWG MicroUSB Cable Our all-in-one 5V 2.5 Amp + MicroUSB cable power adapter is the perfect choice for powering single-board computers like Raspberry Pi, BeagleBone, or anything else that's... https://www.adafruit.com/product/1995 Alternatively, if you really need a lot of power, use a 5V 4A power adapter and then a DC to micro USB adapter 5V 4A (4000mA) switching power supply UL Listed Need a lot of 5V power? This switching supply gives a clean regulated 5V output at up to 4 Amps (4000mA). 110 or 240 input, so it works in any country. The plugs are "US... https://www.adafruit.com/product/1466 MicroUSB Plug to 5.5/2.1mm DC Barrel Jack Adapter The premise of this MicroUSB Plug to 5.5/2.1mm Jack adapter is simple. There's a MicroUSB plug on one end and a 5.5mm/2.1mm DC barrel jack with center... https://www.adafruit.com/product/2727 ©Adafruit Industries Page 11 of 32 I2S Audio Data Pins The Bonnet uses 3 data pins and they cannot be changed! Pins #18, #19 and #21 are used. All other pins are available Speaker Outputs This is the fun part, you get stereo output - one left and one right channel. Each one is Bridge-Tied-Load so do not connect both outputs together to get more volume! You can use the JST 4-pin plug in the center if you're going to just plug in one of our enclosed speaker kits: ©Adafruit Industries Page 12 of 32 Stereo Enclosed Speaker Set - 3W 4 Ohm Listen up! This set of two 2.8" x 1.2" speakers are the perfect addition to any audio project where you need 4 ohm impedance and 3W or less of power. We particularly like... https://www.adafruit.com/product/1669 OR You can use the terminal block spots on the left & right to connect regular speaker cones. You'll need to solder wires on and such but this way you can use whatever speaker you like! We suggest 8 ohm 1W or 4 ohm 3W. For louder audio, but more power usage, use the 4 ohm speakers. For quieter audio, but less power usage, use the 8 ohm speakers Speaker - 3" Diameter - 4 Ohm 3 Watt Listen up! This 3" diameter speaker cone is the perfect addition to any audio project where you need an 4 ohm impedance and 3W or less of power. We particularly like this cone as... https://www.adafruit.com/product/1314 Speaker - 3" Diameter - 8 Ohm 1 Watt Listen up! This 3" diameter speaker cone is the perfect addition to any audio project where you need an 8 ohm impedance and 1W or less of power. We particularly like this cone as... https://www.adafruit.com/product/1313 ©Adafruit Industries Page 13 of 32 You can also use other 'audio' devices like sonic transducers! These are devices you can put down onto a surface like a table, to make it into a speaker. Medium Surface Transducer with Wires - 4 Ohm 3 Watt Turn any surface/wall/table etc into a speaker with a surface transducer. This type of speaker does not have a moving cone like most speakers you've seen. Instead, a small metal... https://www.adafruit.com/product/1785 Raspberry Pi Setup At this time, Raspbery Pi linux kernel does not support mono audio out of the I2S interface, you can only play stereo, so any mono audio files may need conversion to stereo! 2017-11-2 Raspbian PIXEL ('full') has broken something in volume control. I2S works, but there's no software volume setup, if you need this, try Raspbian Lite will try to fix as soon as we figure out why :) Fast Install Luckily its quite easy to install support for I2S DACs on Raspbian. These instructions are totally cribbed from the PhatDAC instructions at the lovely folks at Pimoroni! (https://adafru.it/nFy) Run the following from your Raspberry Pi with Internet connectivity: curl -sS https://raw.githubusercontent.com/adafruit/Raspberry-PiInstaller-Scripts/master/i2samp.sh | bash ©Adafruit Industries Page 14 of 32 We've added an extra helper systemd script that will play quiet audio when the I2S peripheral isn't in use. This removes popping when playback starts or stops. It uses a tiny amount of CPU time (on a Pi Zero, 5%, on a Pi 2 or 3 its negligible). You don't need this on RetroPie because it never releases the I2S device, but it's great for Raspbian. You will need to reboot once installed. You must reboot to enable the speaker hardware! After rebooting, log back in and re-run the script again...It will ask you if you want to test the speaker. Say yes and listen for audio to come out of your speakers... ©Adafruit Industries Page 15 of 32 If it sounds really distorted, it could be the volume is too high. However, in order to have volume control appear in Raspbian desktop or Retropie you must reboot a second time after doing the speaker test, with sudo reboot You must reboot *twice* to enable alsamixer volume (really!) Once rebooted, try running alsamixer and use arrow keys to lower the volume, 50% is a good place to start. If you're still having audio problems, try re-running the script and saying N (disable) the /dev/zero playback service . You can then go to the next page on testing and optimizing your setup. Skip the rest of this page on Detailed Installation if the script worked for you! Detailed Install If, for some reason, you can't just run the script and you want to go through the install by hand - here's all the steps! Update /etc/modprobe.d (if it exists) Log into your Pi and get into a serial console (either via a console cable, the TV console, RXVT, or what have you) Edit the raspi blacklist with ©Adafruit Industries Page 16 of 32 sudo nano /etc/modprobe.d/raspi-blacklist.conf If the file is empty, just skip this step However, if you see the following lines: blacklist i2c-bcm2708 blacklist snd-soc-pcm512x blacklist snd-soc-wm8804 Update the lines by putting a # before each line ©Adafruit Industries Page 17 of 32 Save by typing Control-X Y Disable headphone audio (if it's set) Edit the raspi modules list with sudo nano /etc/modules If the file is empty, just skip this step However, if you see the following line: snd_bcm2835 Put a # in front of it and save with Control-X Y Create asound.conf file Edit the raspi modules list with sudo nano /etc/asound.conf ©Adafruit Industries Page 18 of 32 This file ought to be blank! Copy and paste the following text into the file pcm.speakerbonnet { type hw card 0 } pcm.dmixer { type dmix ipc_key 1024 ipc_perm 0666 slave { pcm "speakerbonnet" period_time 0 period_size 1024 buffer_size 8192 rate 44100 channels 2 } } ctl.dmixer { type hw card 0 } pcm.softvol { type softvol slave.pcm "dmixer" control.name "PCM" control.card 0 } ctl.softvol { type hw card 0 } pcm.!default { type slave.pcm } ©Adafruit Industries plug "softvol" Page 19 of 32 Save the file as usual Add Device Tree Overlay  Edit your Pi configuration file with sudo nano /boot/config.txt And scroll down to the bottom. If you see a line that says: dtparam=audio=on  Disable it by putting a # in front. ©Adafruit Industries Page 20 of 32 Then add: dtoverlay=hifiberry-dac dtoverlay=i2s-mmap on the next line. Save the file. Reboot your Pi with sudo reboot Raspberry Pi Test Speaker Tests! OK you can use whatever software you like to play audio but if you'd like to test the speaker output, here's some quick commands that will let you verify your amp and speaker are working as they should! Simple white noise speaker test Run speaker-test -c2 to generate white noise out of the speaker, alternating left and right. If you have a mono output amplifier, the I2S amp merges left and right channels, so you'll hear continuous white noise ©Adafruit Industries Page 21 of 32 Simple WAV speaker test Once you've got something coming out, try to play an audio file with speaker-test (for WAV files, not MP3) speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/ Front_Center.wav You'll hear audio coming from left and right alternating speakers Simple MP3 speaker test If you want to play a stream of music, you can try sudo apt-get install -y mpg123 mpg123 http://ice1.somafm.com/u80s-128-mp3 If you want to play MP3's on command, check out this tutorial which covers how to set that up (https://adafru.it/aTD) At this time, Jessie Raspbery Pi kernel does not support mono audio out of the I2S interface, you can only play stereo, so any mono audio files may need conversion to stereo! omxplayer does not seem use the I2S interface for audio - only HDMI - so you won't be able to use it Volume adjustment Many programs like PyGame and Sonic Pi have volume control within the application. For other programs you can set the volume using the command line tool called alsam ixer. Just type alsamixer in and then use the up/down arrows to set the volume. Press Escape once its set ©Adafruit Industries Page 22 of 32 In Raspbian PIXEL you can set the volume using the menu item control. If it has an X through it, try restarting the Pi (you have to restart twice after install to get PIXEL to recognize the volume control Pi I2S Tweaks This page is deprecated, our installer already performs these steps for you, but we'll keep them here for archival use! ©Adafruit Industries Page 23 of 32 Reducing popping For people who followed our original installation instructions with the simple alsa config, they may find that the I2S audio pops when playing new audio. The workaround is to use a software mixer to output a fixed sample rate to the I2S device so the bit clock does not change. I use ALSA so I configured dmixer and I no longer have any pops or clicks. Note that the RaspPi I2S driver does not support dmix er by default and you must follow these instructions provided (https://adafru.it/sHF) to add it. Continue on for step-by-step on how to enable it! Step 1 Start by modify /boot/config.txt to add dtoverlay=i2s-mmap Run sudo nano /boot/config.txt and add the text to the bottom like so: Save and exit. Then change /etc/asound.conf to: pcm.speakerbonnet { type hw card 0 } pcm.!default { type plug slave.pcm "dmixer" } pcm.dmixer { type dmix ipc_key 1024 ipc_perm 0666 slave { pcm "speakerbonnet" ©Adafruit Industries Page 24 of 32 period_time 0 period_size 1024 buffer_size 8192 rate 44100 channels 2 } } ctl.dmixer { type hw card 0 } By running sudo nano /etc/asound.conf This creates a PCM device called speakerbonnet which is connected to the hardware I2S device. Then we make a new 'dmix' device ( type dmix ) called pcm.dmixer . We give it a unique Inter Process Communication key ( ipc_key 1024 ) and permissions that are world-read-writeable (ipc_perm 0666 ) The mixer will control the hardware pcm device speakerbonnet (pcm "speakerbonnet") and has a buffer set up so its nice and fast. The communication buffer is set up so there's no delays ( period_time 0 , period_size 1024 and buffer_size 8192 work well). The default mixed rate is 44.1khz stereo ( rate 44100 channels 2 ) Finally we set up a control interface but it ended up working best to just put in the hardware device here - ctl.dmixer { type hw card 0 } Save and exit. Then reboot the Pi to enable the mixer. Also, while it will greatly reduce popping, you still may get one once in a while - especially when first playing audio! ©Adafruit Industries Page 25 of 32 Add software volume control The basic I2S chipset used here does not have software control built in. So we have to 'trick' the Pi into creating a software volume control. Luckily, its not hard once you know how to do it (https://adafru.it/ydQ). Create a new audio config file in ~/.asoundrc with nano ~/.asoundrc and inside put the following text: pcm.speakerbonnet { type hw card 0 } pcm.dmixer { type dmix ipc_key 1024 ipc_perm 0666 slave { pcm "speakerbonnet" period_time 0 period_size 1024 buffer_size 8192 rate 44100 channels 2 } } ctl.dmixer { type hw card 0 } pcm.softvol { type softvol slave.pcm "dmixer" control.name "PCM" control.card 0 } ctl.softvol { type hw card 0 } pcm.!default { type slave.pcm } plug "softvol" This assumes you set up the dmixer for no-popping above! ©Adafruit Industries Page 26 of 32 Save and exit Now, here's the trick, you have to reboot, then play some audio through alsa, then reboot to get the alsamixer to sync up right: speaker-test -c2 --test=wav -w /usr/share/sounds/alsa/ Front_Center.wav Then you can type alsamixer to control the volume with the 'classic' alsa mixing interface Just press the up and down arrows to set the volume, and ESC to quit ©Adafruit Industries Page 27 of 32 I2S Audio FAQ Hey in Raspbian Pixel desktop, the speaker icon is X'd out! Try rebooting once after playing some audio. Also make sure you have our latest alsa configuration (check the detailed install page on the Raspberry Pi Setup page for the /etc/asound.conf ! If its still not working, you can still change the volume, just use alsamixer from a Terminal command prompt. Even with dmixer enabled, I get a staticy-pop when the Pi first boots or when it first starts playing audio Yep, this is a known Raspbian Linux thing. Yay Linux! We don't have a fix for it. If it makes you feel better, my fancy Windows development computer does the same thing with my desktop speakers. You can reduce popping a lot with the '/dev/zero play' option in the i2s setup script. (We added it in October 2018) but you still might get that one initial pop The audio on my DAC sounds really bad/distorted Make sure you've lowered the volume. The default is 100% which is waaaay too high! Use alsamixer to reduce the volume to 50% or so Does this work with my favorite software? It will work with anything that has alsa audio support. There's thousands of linux programs so we can't guarantee all of them will work but here's what we found does for sure! • PyGame - see our page on playing audio with PyGame (https://adafru.it/ydS) for example code. Volume can be controlled within pygame • mpg123 - command line mp3 audio playback. use alsamixer to control the volume • aplay - for playing wav files on the command line • Sonic Pi - tested in the Pixel Desktop. Use the Sonic Pi settings panel to change the volume - it does not seem to care about what global audio volume you set! ©Adafruit Industries Page 28 of 32 • Scratch 2 - tested in the Pixel Desktop. Works fine but may have a delay and make a popping sound the first time you play audio. You can set volume with alsamixer and also via the app by using the set volume to nn% block • Scratch 1 - doesn't work, something not set up with Scratch 1 to use alsa? • RetroPie/Emulation Station - audio works within games (we tested NES and MAME libretro) but does not work in the 'main screen' (selecting which game to play interface) Play Audio with PyGame You can use mpg123 for basic testing but it's a little clumsy for use where you want to dynamically change the volume or have an interactive program. For more powerful audio playback we suggest using PyGame to playback a variety of audio formats (MP3 included!) Install PyGame Start by installing pygame support, you'll need to open up a console on your Pi with network access and run: sudo apt-get install python-pygame Next, download this pygame example zip to your Pi Click to download PyGame example code & sample mp3s https://adafru.it/wbp On the command line, run wget https://cdn-learn.adafruit.com/assets/assets/000/041/506/ original/pygame_example.zip (https://adafru.it/wbq) unzip pygame_example.zip (https://adafru.it/wbq) Run Demo Inside the zip is an example called pygameMP3.py ©Adafruit Industries Page 29 of 32 This example will playback all MP3's within the script's folder. To demonstrate that you can also adjust the volume within pygame, the second argument is the volume for playback. Specify a volume to playback with a command line argument between 0.0 and 1.0 For example here is how to play at 75% volume: python pygameMP3.py 0.75 Here's the code if you have your own mp3s! ''' pg_midi_sound101.py play midi music files (also mp3 files) using pygame tested with Python273/331 and pygame192 by vegaseat ''' #code modified by James DeVito from here: https://www.daniweb.com/programming/ software-development/code/454835/let-pygame-play-your-midi-or-mp3-files #!/usr/bin/python import import import import sys pygame as pg os time def play_music(music_file): ''' stream music with mixer.music module in blocking manner this will stream the sound from disk while playing ''' clock = pg.time.Clock() try: pg.mixer.music.load(music_file) print("Music file {} loaded!".format(music_file)) except pygame.error: print("File {} not found! {}".format(music_file, pg.get_error())) return pg.mixer.music.play() # If you want to fade in the audio... # for x in range(0,100): # pg.mixer.music.set_volume(float(x)/100.0) # time.sleep(.0075) # # check if playback has finished while pg.mixer.music.get_busy(): clock.tick(30) freq = 44100 # audio CD quality bitsize = -16 # unsigned 16 bit channels = 2 # 1 is mono, 2 is stereo buffer = 2048 # number of samples (experiment to get right sound) pg.mixer.init(freq, bitsize, channels, buffer) if len(sys.argv) > 1: try: ©Adafruit Industries Page 30 of 32 user_volume = float(sys.argv[1]) except ValueError: print "Volume argument invalid. Please use a float (0.0 - 1.0)" pg.mixer.music.fadeout(1000) pg.mixer.music.stop() raise SystemExit print("Playing at volume: " + str(user_volume)+ "\n") pg.mixer.music.set_volume(user_volume) mp3s = [] for file in os.listdir("."): if file.endswith(".mp3"): mp3s.append(file) print mp3s for x in mp3s: try: play_music(x) time.sleep(.25) except KeyboardInterrupt: # if user hits Ctrl/C then exit # (works only in console mode) pg.mixer.music.fadeout(1000) pg.mixer.music.stop() raise SystemExit else: print("Please specify volume as a float! (0.0 - 1.0)") Downloads Datasheets & Files • MAX98357 Datasheet (https://adafru.it/nFz) • EagleCAD PCB files (https://adafru.it/t1d) • Fritzing object in Adafruit Fritzing library (https://adafru.it/c7M) ©Adafruit Industries Page 31 of 32 Schematic Fabrication Print Dims in mm ©Adafruit Industries Page 32 of 32
很抱歉,暂时无法提供与“3346”相匹配的价格&库存,您可以联系我们找货
  • 1+103.193451+13.33768
库存:31
3346
    • 1+40.326751+5.21220
    库存:31
    3346
    • 1+113.805161+14.70923
    库存:29
    3346
    • 1+113.539501+14.67490
    库存:31
