102990208
102990208
    SEEED(矽递科技)
    PHOENARDPHOENEXBREADBOARD
102990208 数据手册
Phoenard Phoenex Breadboard SKU 102990208 DESCRIPTION This Phoenard board extension can be docked using the bottom 30-pin connector, breaking out the 30-pin connector. You can then develop your own electronic designs with or using the circuit prototyping breadboard and jumper wires. Features Breadboard mounted on top of standard Phoenex proto Female 2.54 mm headers installed on pin headers Specification Safe operating conditions         Temperature: -10 ~ 60 degrees celcius Humidity: 20% - 90% Power         Main board voltage: 3v3 Accessible pins         Analog: 6 analog pins (A0 - A5) Digital: 5 general purpose I/O; supports PWM (digital pins 4, 5, 6, 7, 9) ISP Interface: 6-pin (MISO/MOSI/SCK/SS/RESET/GND) I2C Interface: SDA/SCL Audio: Left/Right/Audio Gnd Serial Interface: Serial 1 (RX0/TX0) Power: 3v3 (main board), 5v (USB power) Part List 1 x Phoenex Breadboard PCBA Note This board uses a 3v3 main board voltage and may not be compatible with all 5v sensors and devices. The 5v power on the extension connector is only present when USB power is provided. A starters guide together with documentation and software examples is available on our website: Getting started Software documentation Forums Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved
102990208 价格&库存
很抱歉,暂时无法提供与“102990208”相匹配的价格&库存,您可以联系我们找货
