102990206
102990206
    SEEED(矽递科技)
    PHOENARDPHOENEXSHIELD
102990206 数据手册
Phoenard Phoenex Shield SKU 102990206 DESCRIPTION This Phoenard board extension can be docked using the bottom 30-pin connector, exposing most (not all!) Arduino pins. You can then connect Arduino board extensions to the device easily. Features Standard Arduino shield design Functional ISP interface and digital/analog I/O Specification Safe operating conditions         Temperature: -10 ~ 60 degrees celcius Humidity: 20% - 90% Power         Main board voltage: 3v3 Accessible pins         Analog: 6 analog pins (A0 - A5) Digital: 5 general purpose I/O; supports PWM (digital pins 4, 5, 6, 7, 9) ISP Interface: 6-pin (MISO/MOSI/SCK/SS/RESET/GND) Serial Interface: Serial 1 (RX0/TX0) Power: 3v3 (main board), 5v (USB power) Part List 1 x Phoenex Shield PCBA Note This board uses a 3v3 main board voltage and may not be compatible with all 5v sensors and devices. The 5v power on the extension connector is only present when USB power is provided. A starters guide together with documentation and software examples is available on our website: Getting started Software documentation Forums Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved
102990206 价格&库存
很抱歉,暂时无法提供与“102990206”相匹配的价格&库存,您可以联系我们找货
