(images/product/102990344 1_01.jpg)
96Boards Sensors
SKU: 102990344
Description
The 96Boards Sensors Mezzanine adapter makes it simple and easy to connect sensors and
devices to any 96Boards-compatible base board. With it you can connect your favourite Grove
modules and Arduino compatible shields and interface to software running on the 96Boards
baseboard. It provides everything you need to start experimenting and prototyping on the
96Boards platform.
On the board you will find sockets for 18 Grove modules, an Arduino-compatible shield
socket, and two SPI headers. It also includes an ATMega328 microcontroller which can be
programmed from the Arduino IDE and will run most Arduino UNO sketches unchanged. The
shield connector and 10 of the Grove sockets are controlled by the microcontroller, while the
remaining 8 Grove sockets are controlled directly by the baseboard. This makes it a flexible
prototyping platform which supports both direct control of devices from application software,
and offload to a microcontroller. It also provides a USB-UART interface to access the
baseboard’s serial console.
The Sensors board attached on top of a 96Boards CE or EE edition board using the 40pin lowspeed expansion connector.
Please note: A 96Boards baseboard is not included.
This board has been tested and works with the Qualcomm Dragonboard 410c and the
LeMaker HiKey boards.
Features
• Integrated ATMEGA328p microcontroller (Arduino compatible)
• 18 Grove connectors
http://www.seeedstudio.com/wiki/Grove_System
5x baseboard GPIO ports
5x I2C ports (1 for baseboard, 2 for microcontroller)
5 digital ports (for microcontroller)
3x analog ports (for microcontroller)
2x SPI connectors (1 to baseboard, 1 to microcontroller)
Arduino UNO compatible shield connectors
LED: Power, Reset, 2x baseboard GPIO, 1x microcontroller IO
UART interface between baseboard and microcontroller
USB-UART connector for baseboard console and control
Part List
1x 96Boards Sensors Board
4x M2.5 8mm nylon spacer
4x M2.5 nylon screw
For any technical support or suggestion, please kindly go to our forum
(https://www.96boards.org/forums/).
http://www.seeedstudio.com/depot/96Boards-Sensors-p-2617.html?cPath=122_163
3/29/2016
很抱歉,暂时无法提供与“102990344”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 2+219.824592+28.45401
