1947
1947
    ADAFRUIT
    HEX STANDOFF 4-40 BRASS 1"
1947 数据手册
MULTI-INNO TECHNOLOGY CO., LTD. www.multi-inno.com LCD MODULE SPECIFICATION Model : MI0283QT-11 For Customer's Acceptance: Customer Approved Comment Revision 1.2 Engineering Date Our Reference 2012-11-26 MODULE NO.: MI0283QT-11 Ver 1.2 REVISION RECORD REV NO. REV DATE CONTENTS 1.0 2011-06-22 First release 1.1 2012-02-03 Update interface description 1.2 2012-11-26 Update power consumption MULTI-INNO TECHNOLOGY CO.,LTD. REMARKS P.2 MODULE NO.: MI0283QT-11 Ver 1.2 CONTENTS  GENERAL INFORMATION  EXTERNAL DIMENSIONS  ABSOLUTE MAXIMUM RATINGS  ELECTRICAL CHARACTERISTICS  BACKLIGHT CHARACTERISTICS  ELECTRO-OPTICAL CHARACTERISTICS  INTERFACE DESCRIPTION  APPLICATION NOTES  INITIAL CODE  RELIABILITY TEST  INSPECTION CRITERION  PRECAUTIONS FOR USING LCD MODULES  USING LCD MODULES  PRIOR CONSULT MATTER MULTI-INNO TECHNOLOGY CO.,LTD. P.3 MODULE NO.: MI0283QT-11 Ver 1.2  GENERAL INFORMATION Item LCD type Viewing direction Gray scale inversion direction Module area (W × H) Active area (W×H) Number of Dots Pixel pitch(W × H) DriverIC Colors Backlight Type Module Power consumption InterfaceType Input voltage With/Without TSP Weight Contents TFT/TRANSMISSIVE/POSITIVE 6:00 12:00 50.2×69.3×4.0 43.2×57.6 240(RGB)×320 0.18 × 0.18 ILI9341 65K/262K 4 LEDs 220 CPU/RGB 2.8 With TSP 24.16 Unit/Note / O’Clock O’Clock mm2 mm2 / mm2 / / / mw / V / g Note 1:Viewing direction for best image quality is different from TFT definition, there is a 180 degree shift. Note 2 : RoHS compliant; Note 3: LCM weight tolerance: ± 5% . MULTI-INNO TECHNOLOGY CO.,LTD. P.4 MODULE NO.: MI0283QT-11 Ver 1.2  EXTERNAL DIMENSIONS MULTI-INNO TECHNOLOGY CO.,LTD. P.5 Ver 1.2 MODULE NO.: MI0283QT-11 ABSOLUTE MAXIMUM RATINGS Parameter Power supply voltage Logic signal voltage Operatingtemperature Storagetemperature Humidity Symbol VCI VDDI Top TST Min -0.3 -0.3 -20 -30 RH - Max 4.6 4.6 70 80 90%(Max60 °C) Unit V V °C °C RH ELECTRICAL CHARACTERISTICS DC CHARACTERISTICS Parameter Power supply voltage Logic signalI/O voltage Inputvoltage'H'level Inputvoltage'L'level Outputvoltage'H'level Outputvoltage'L'leve Symbol VCI VDDI VIH VIL VOH VOL Min 2.5 1.65 0.7VDDI VSS 0.8VDDI VSS0 Typ 2.8 2.8 - Max 3.3 3.3 VDDI 0.3VDDI VDDI 0.2VDDI Unit V V V V V V Note: 1: Display full white. Backlight on state. 2: IC on standby mode. 3: the default voltage is 2.8V, for N lights in series, the power is that the current multiply N.  BACKLIGHT CHARACTERISTICS Item Symbol Supply voltage Vf Supply current - Reverse voltage Vr Forward current Normal Condition If=80mA - - Ipd Reverse Current Ir - Uniformity ϦBp X Color coordinate* Y MULTI-INNO TECHNOLOGY CO.,LTD. Typ Max Unit - 3.2 - - - mA - - - V 80 - Ipn 4-chip Parallel Dimming Min 3.4 Note V 1 mA - - - µA 0.270 - 0.315 - 0.270 - 0.315 - 80% If=80mA P.6 MODULE NO.: MI0283QT-11 Ver 1.2 White LED CIRCUIT DIAGRAM: NOTE: 1 The LED ‘s driver mode needs to be constant current mode.  Permanent damage to the device may occur if maximum values are exceeded or reverse voltage is loaded .Functional operation should be restricted to the conditions described under normal operating conditions. MULTI-INNO TECHNOLOGY CO.,LTD. P.7 Ver 1.2 MODULE NO.: MI0283QT-11 ELECTRO-OPTICAL CHARACTERISTICS Item Symbol Response time Contrastratio Luminance uniformity Surface Luminance Tr +Tf Cr δ WHITE Lv Viewing angle range CIE (x, y) chromaticity NTSC Ratio θ Red x Red y Green x Green y Blue x Blue y White x White y S Condition θ=0° ∅=0° Ta=25 ∅ = 90° ∅ = 270° ∅ = 0° ∅ = 180° θ=0° ∅=0° Ta=25 Min 80 150 55 Typ Max Unit Remark Note 25 500 90.8 240 70 57 70 70 0.6368 0.3329 0.3397 0.6138 0.1433 0.0807 0.2886 0.3194 67 30 - ms ---% cd/m 2 deg deg deg deg Fig.1 FIG 2. FIG 2. FIG 2. FIG 3. FIG 3. FIG 3. FIG 3. 4 1 3 2 FIG 2. 5 6 % Note 1. Contrast Ratio(CR) is defined mathematically as For more information see FIG 2.: Contrast Ratio = Average Surface Luminance with all white pixels (P 1,P2, P 3,P4, P5) Average Surface Luminance with all black pixels (P1, P2, P 3,P4, P5) Note 2. Surface luminance is the LCD surface from the surface with all pixels displaying white. information see FIG 2. Lv = Average Surface Luminance with all white pixels (P1, P2, P 3,P4, P5) For more Note 3. The uniformity in surface luminance , δ WHITE is determined by measuring luminance at each test position 1 through 5, and then dividing the maximum luminance of 5 points luminance by minimum luminance of 5 points luminance. For more information see FIG 2. Minimum Surface Luminance with all white pixels (P1, P2, P 3,P4, P5) δ WHITE = Maximum Surface Luminance with all white pixels (P1, P2, P 3,P4, P5) Note 4. Response time is the time required for the display to transition from White to black(Rise Time, Tr) and from black to white(Decay Time, Tf). For additional information see FIG 1. The test equipment is Autronic-Melchers’s ConoScope. Series Note 5. CIE (x, y) chromaticity,The x,y value is determined by measuring luminance at each test position 1 through 5,and then make average value Note 6. Viewing angle is the angle at which the contrast ratio is greater than 2. For TFT module the conrast ratio is greater than 10. The angles are determined for the horizontal or x axis and the vertical or y axis with respect to the z axis which is normal to the LCD surface. For more information see FIG 3. Note 7. For Viewing angle and response time testing, the testing data is base on Autronic-Melchers’s ConoScope. Series Instruments. For contrast ratio, Surface Luminance, Luminance uniformity,CIE The test data is base on TOPCON’s BM-5 photo detector. Note 8. For TFT module, Gray scale reverse occurs in the direction of panel viewing angle. MULTI-INNO TECHNOLOGY CO.,LTD. P.8 MODULE NO.: MI0283QT-11 Ver 1.2 FIG.1. The definition of Response Time FIG.2. Measuring method for Contrast ratio,surface luminance, Luminance uniformity CIE (x, y) chromaticity A : 5 mm B : 5 mm H,V : Active Area Light spot size ∅=5mm, 500mm distance from the LCD surface to detector lens measurement instrument is TOPCON’s luminance meter BM-5 FIG.3. The definition of viewing angle MULTI-INNO TECHNOLOGY CO.,LTD. P.9 MODULE NO.: MI0283QT-11 Ver 1.2  INTERFACE DESCRIPTION Pin No. Symbol I/O Function 1 LEDK I Cathode for LED backlighting 2 LEDA1 I Anode No.1 for LED backlighting 3 LEDA2 I Anode No.2 for LED backlighting 4 LEDA3 I Anode No.3 for LED backlighting 5 LEDA4 I Anode No.4 for LED backlighting 6 IM0 I 7 IM1 I 8 IM2 I 9 IM3 I 10 RESET I Reset pin 11 VSYNC IO Frame Synchronizing Signal For RGB Interface 12 HSYNC IO Line Synchronizing Signal For RGB Interface 13 DOTCLK IO Dot Clock Signal For RGB Interface 14 IO Data Enable Signal For RGB Interface 15 DE DB17 | | IO DATA BUS 32 Select Interface Mode ;Note1 DB0 33 SDO IO Serial Output Signal 34 SDI IO Serial Input Signal 35 RD IO Read execution control pin 36 WRX(D/CX) IO Write execution control pin ; Serial Register select s Signal 37 D/CX(SCL) IO Register select signal; Serial Interface Clock 38 CSX IO Chip Select Signal 39 TE IO Tearing effect out pin synchronize MPU to frame writng 40 VDDI P Power Supply to the interface pins ,provide with 2.8V 41 VDDI P Power Supply to the interface pins ,provide with 2.8V 42 VCI P Logic power ,provide with 2.8V 43 GND G Ground 44 X+ O Touch panel output 45 Y+ O Touch panel output 46 X- O Touch panel output 47 Y- O Touch panel output 48 GND O Ground 49 GND O Ground 50 GND - Ground MULTI-INNO TECHNOLOGY CO.,LTD. P.10 MODULE NO.: MI0283QT-11 Ver 1.2 NOTE1: MULTI-INNO TECHNOLOGY CO.,LTD. P.11 Ver 1.2 MODULE NO.: MI0283QT-11  APPLICATION NOTES 1.1 Interface Timing Chart Note: Please refer to ILITEK’s ILITEK’s ILI9341 ILI9341 data sheet for more details. INTERFACE PROTOCOL Inter 80 system CPU interface D/CX tchw tast taht tchw tcs CSX tcsf twc WRX twrl twrh tdht tdst D[17:0] (Write) tast taht trcs / trcsfm trc / trcfm trdl / trdlfm RDX trdh / trdhfm trat / tratfm trodh D[17:0] (Read) Signal DCX CSX WRX RDX (FM) RDX (ID) D[17:0], D[17:10]&D[8:1], D[17:10], D[17:9] Symbo l tast taht tchw tcs trcs trcsfm tcsf twc twrh twrl trcfm trdhfm trdlfm trc trdh trdl tdst tdht trat tratfm trod Parameter min max Unit Address setup time Address hold time (Write/Read) CSX “H” pulse width Chip Select setup time (Write) Chip Select setup time (Read ID) Chip Select setup time (Read FM) Chip Select Wait time (Write/Read) Write cycle Write Control pulse H duration Write Control pulse L duration Read Cycle (FM) Read Control H duration (FM) Read Control L duration (FM) Read cycle (ID) Read Control pulse H duration Read Control pulse L duration Write data setup time Write data hold time Read access time Read access time Read output disable time 0 0 0 15 45 355 10 66 15 15 450 90 355 160 90 45 10 10 20 40 340 80 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns Description For maximum CL=30pF For minimum CL=8pF Note: Ta = -30 to 70 °C, VDDI=1.65V to 3.3V, VCI=2.5V to 3.3V, VSS=0V.  tr Љ15ns tf Љ15ns 70% 30% MULTI-INNO TECHNOLOGY CO.,LTD. 70% 30% P.12 Ver 1.2 MODULE NO.: MI0283QT-11 INSTRUCTION DESCRIPTION(ILITEK’s ILI9341 Regulative Command Set Command Function D17-8 D7 D6 D5 D4 D3 D2 D1 D0 Hex No Operation 0 1 ↑ XX 0 0 0 0 0 0 0 0 00h Software Reset 0 1 ↑ XX 0 0 0 0 0 0 0 1 01h 0 1 ↑ XX 0 0 0 0 0 1 0 0 04h 1 ↑ 1 XX X X X X X X X X 1 ↑ 1 XX ID1 [7:0] XX 1 ↑ 1 XX ID2 [7:0] XX 1 ↑ 1 XX 0 1 ↑ XX 0 0 0 1 ↑ 1 XX X X X 1 ↑ 1 XX 1 ↑ 1 XX X X Read Display Identification Information Read Display Status Read Display Power Mode Read Display MADCTL Read Display Pixel Format Read Display Image Format Read Display Signal Mode Read Display Self-Diagnostic Result Enter Sleep Mode D/CX RDX WRX ID3 [7:0] XX 0 1 0 0 X X X X D [31:25] 1 ↑ 1 XX ↑ 1 XX 0 1 ↑ XX 0 0 X X X 1 09h X XX X D [22:20] 1 D [19:16] X XX 00 61 X X X X X X X 00 0 0 1 0 1 0 0Ah X X X X X X XX 0 0 08 D [7:5] D [10:8] 00 1 ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX 0 0 0 0 1 0 1 1 0Bh X X X X X X X X XX 0 0 00 0 0 0Ch X X XX 0 1 0Dh X X XX 1 ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX D [7:2] D [7:2] 0 0 X 1 ↑ 1 XX X 1 ↑ 1 XX RIM 0 1 ↑ XX 0 0 0 X X DPI [2:0] 0 1 1 X X X 0 0 DBI [2:0] 1 1 X 06 1 ↑ 1 XX X X X X X 1 ↑ 1 XX X X X X X 0 1 ↑ XX 0 0 0 0 1 1 1 0 0Eh X X X X X X X X XX 0 0 00 1 1 0Fh XX 1 ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX 0 0 X X D [2:0] D [7:2] 1 ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX 0 0 0 1 1 00 X X X X X X X X X X X X 00 0 0 1 0 0 0 0 10h D [7:6] Sleep OUT 0 1 ↑ XX 0 0 0 1 0 0 0 1 11h Partial Mode ON 0 1 ↑ XX 0 0 0 1 0 0 1 0 12h Normal Display Mode ON 0 1 ↑ XX 0 0 0 1 0 0 1 1 13h Display Inversion OFF 0 1 ↑ XX 0 0 1 0 0 0 0 0 20h Display Inversion ON 0 1 ↑ XX 0 0 1 0 0 0 0 1 21h 0 1 ↑ XX 0 0 1 0 0 1 1 0 26h 1 1 ↑ XX Display OFF 0 1 ↑ XX 0 0 1 0 1 0 0 0 28h Display ON 0 1 ↑ XX 0 0 1 0 1 0 0 1 29h 0 1 ↑ XX 0 0 1 0 1 0 1 0 2Ah 1 1 ↑ XX SC [15:8] 1 1 ↑ XX SC [7:0] XX 1 1 ↑ XX EC [15:8] XX 1 1 ↑ XX 0 1 ↑ XX 1 1 ↑ XX SP [15:8] 1 1 ↑ XX SP [7:0] XX 1 1 ↑ XX EP [15:8] XX 1 1 ↑ XX EP [7:0] XX Gamma Set Column Address Set Page Address Set MULTI-INNO TECHNOLOGY CO.,LTD. GC [7:0] 01 XX EC [7:0] 0 0 1 0 XX 1 0 1 1 2Bh XX P.13 Ver 1.2 MODULE NO.: MI0283QT-11 Memory Write Color SET Memory Read Partial Area Vertical Scrolling Definition Tearing Effect Line OFF Tearing Effect Line ON Memory Access Control 0 1 ↑ 1 1 ↑ 0 1 ↑ XX 1 ↑ 1 XX R00 [5:0] XX 1 ↑ 1 XX Rnn [5:0] XX 1 ↑ 1 XX R31 [5:0] XX 1 ↑ 1 XX G00 [5:0] XX 1 ↑ 1 XX Gnn [5:0] XX 1 ↑ 1 XX G64 [5:0] XX 1 ↑ 1 XX B00 [5:0] XX XX 0 0 1 0 1 1 0 0 2Ch 1 1 0 1 2Dh D [17:0] 0 0 1 0 XX 1 ↑ 1 XX Bnn [5:0] XX 1 ↑ 1 XX B31 [5:0] XX 0 1 ↑ XX 0 0 1 0 1 1 1 0 1 ↑ 1 XX X X X X X X X X 1 ↑ 1 0 1 ↑ XX 1 1 ↑ XX SR [15:8] 00 1 1 ↑ XX SR [7:0] 00 1 1 ↑ XX ER [15:8] 01 1 1 ↑ XX ER [7:0] 3F 0 1 ↑ XX 1 1 ↑ XX TFA [15:8] 00 1 1 ↑ XX TFA [7:0] 00 1 1 ↑ XX VSA [15:8] 01 1 1 ↑ XX VSA [7:0] 40 D [17:0] 0 0 0 0 1 1 1 XX XX 0 1 2Eh 0 0 0 0 0 1 1 30h 33h 1 1 ↑ XX BFA [15:8] 00 1 1 ↑ XX BFA [7:0] 00 0 1 ↑ XX 0 0 1 1 0 1 0 0 34h 0 1 ↑ XX 0 0 1 1 0 1 0 1 35h 1 1 ↑ XX X X X X X X X M 00 36h 0 1 ↑ XX 0 0 1 1 0 1 1 0 1 1 ↑ XX MY MX MV ML BGR MH X X 00 0 1 ↑ XX 0 0 1 1 0 1 1 1 37h 1 1 ↑ XX VSP [15:8] 00 1 1 ↑ XX VSP [7:0] 00 Idle Mode OFF 0 1 ↑ XX 0 0 1 1 1 0 0 0 Idle Mode ON 0 1 ↑ XX 0 0 1 1 1 0 0 1 39h 0 1 ↑ XX 0 0 1 1 1 0 1 0 3Ah 1 1 ↑ XX X XX 0 Vertical Scrolling Start Address Pixel Format Set Write Memory Continue Read Memory Continue Set Tear Scanline Get Scanline Write Display Brightness DPI [2:0] 0 1 ↑ 1 1 ↑ 0 1 ↑ XX 0 0 1 XX X X X 0 1 X 1 DBI [2:0] 38h 66 1 1 0 0 3Ch 1 1 1 1 0 3Eh X X X X X D [17:0] XX 1 ↑ 1 1 ↑ 1 0 1 ↑ XX 0 1 0 0 0 1 0 0 1 1 ↑ XX X X X X X X X STS [8] 1 1 ↑ XX 0 1 ↑ XX 0 1 0 0 0 1 0 1 45h 1 ↑ 1 XX X X X X X X X X XX 1 ↑ 1 XX X X X X X X 1 ↑ 1 XX 0 1 ↑ XX 1 1 ↑ XX MULTI-INNO TECHNOLOGY CO.,LTD. D [17:0] STS [7:0] 1 0 1 0 DBV [7:0] 44h 00 00 GTS [9:8] GTS [7:0] 0 XX XX 00 00 0 0 1 51h 00 P.14 Ver 1.2 MODULE NO.: MI0283QT-11 Read Display Brightness Write CTRL Display Read CTRL Display Write Content Adaptive Brightness Control Read Content Adaptive Brightness Control Write CABC Minimum Brightness Read CABC Minimum Brightness Read ID1 Read ID2 Read ID3 1 ↑ ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX 0 1 1 ↑ XX 0 1 1 ↑ ↑ 1 XX 1 ↑ 0 0 X 1 0 0 1 0 52h X X X X X XX 1 0 DBV [7:0] 1 0 0 1 1 X X BCTRL 53h 00 XX 0 X 1 X 0 X 1 XX X X BCTRL 1 ↑ XX 0 1 0 1 1 ↑ XX X X X 0 1 1 ↑ ↑ 1 XX XX 0 X 1 X 0 X 1 ↑ 1 XX X X X 0 1 ↑ XX 0 1 0 1 1 ↑ XX 0 1 1 ↑ ↑ 1 XX XX 0 X 1 X 0 X 1 ↑ 1 XX 0 1 1 ↑ ↑ 1 XX XX 1 X 1 X 0 X 1 ↑ 1 XX 0 1 ↑ XX 1 1 X X 0 1 XX 0 X 1 X 00 X 1 DD 0 BL 1 X 0 X 0 X X X X X XX X 1 DD 0 BL 1 X 0 X 1 00 55h X 1 X 0 X 1 1 0 00 56h X X X X X XX X 1 X 1 X 1 1 0 00 5Eh CMB [7:0] 1 0 1 1 1 00 5Fh X X X X X XX CMB [7:0] 1 1 0 1 0 00 DAh X X X X XX DBh X C [1:0] C [1:0] Module’s Manufacture [7:0] 54h XX 0 1 1 0 1 1 X X X X X X 1 ↑ 1 XX 1 ↑ 1 XX 0 1 ↑ XX 1 1 0 1 1 1 0 0 DCh 1 ↑ 1 XX X X X X X X X X XX 1 ↑ 1 XX LCD Module / Driver Version [7:0] XX XX LCD Module / Driver ID [7:0] XX Extended Command Set Command Function D17-8 D7 D6 D5 D4 D3 D2 D1 D0 Hex RGB Interface 0 1 ↑ XX 1 0 1 1 0 0 0 0 B0h Signal Control 1 1 ↑ XX ByPass_MODE X VSPL HSPL DPL EPL 40 0 1 ↑ XX 1 0 1 1 0 0 0 1 B1h X X X DIVA [1:0] Frame Control (In Normal Mode) Frame Control (In Idle Mode) Frame Control (In Partial Mode) Display Inversion Control Blanking Porch Control D/CX RDX WRX RCM [1:0] 1 1 ↑ XX X X X 1 1 ↑ XX X X X 0 1 ↑ XX 1 0 1 1 0 0 1 1 1 ↑ XX X X X X X X DIVB [1:0] 1 1 ↑ XX X X X 0 1 ↑ XX 1 0 1 1 0 0 1 1 ↑ XX X X X X X X 1 1 ↑ XX X X X RTNA [4:0] 00 1B 0 RTNB [4:0] B2h 00 1B 1 1 DIVC [1:0] RTNC [4:0] B3h 00 1B 0 1 ↑ XX 1 0 1 1 0 1 0 0 1 1 ↑ XX X X X X X NLA NLB NLC 02 0 1 ↑ XX 1 0 1 1 0 1 0 1 B5h 1 1 ↑ XX 0 VFP [6:0] 1 1 ↑ XX 0 VBP [6:0] 1 1 ↑ XX 0 0 0 HFP [4:0] 0A 1 1 ↑ XX 0 0 0 HBP [4:0] 14 MULTI-INNO TECHNOLOGY CO.,LTD. B4h 02 02 P.15 Ver 1.2 MODULE NO.: MI0283QT-11 Display Function Control Entry Mode Set Backlight Control 1 Backlight Control 2 Backlight Control 3 Backlight Control 4 Backlight Control 5 Backlight Control 7 Backlight Control 8 Power Control 1 Power Control 2 VCOM Control 1 VCOM Control 2 NV Memory Write NV Memory Protection Key NV Memory Status Read 0 1 ↑ XX 1 0 1 1 0 1 1 ↑ XX X X X X PTG [1:0] 1 1 ↑ XX REV GS SS SM 1 1 ↑ XX X X NL [5:0] 27 1 1 ↑ XX X X PCDIV [5:0] XX 1 1 0 PT [1:0] B6h 0A ISC [3:0] 82 0 1 ↑ XX 1 0 1 1 0 1 1 1 1 1 ↑ XX X X X X DSTB GON DTE GAS 07 0 1 ↑ XX 1 0 1 1 1 0 0 0 B8h X X X X XX 0 1 B9h X X XX 1 1 ↑ XX X X X X 1 1 ↑ XX X X X X 0 1 ↑ XX 1 0 1 1 1 0 X X X X X X TH_UI [3:0] B7h 04 1 1 ↑ XX 1 1 ↑ XX 0 1 ↑ XX 1 0 1 1 1 0 1 0 BAh X X X X XX TH_MV [3:0] TH_ST [3:0] B8 1 1 ↑ XX X X X X 1 1 ↑ XX X X X X 0 1 ↑ XX 1 0 1 1 1 0 1 1 BBh X X X X X X X X XX 0 0 BCh X X XX 1 1 ↑ XX 1 1 ↑ XX 0 1 ↑ XX 1 1 1 ↑ XX X 1 1 ↑ XX DTH_UI [3:0] DTH_MV [3:0] DTH_ST [3:0] 0 1 1 X X X DIM2 [3:0] 1 1 X X X 0 1 ↑ XX 1 1 ↑ XX 0 1 ↑ XX 1 0 1 1 1 1 1 ↑ XX X X X X X 0 1 ↑ XX 1 1 0 0 0 1 1 ↑ XX X X 0 1 ↑ XX 1 1 0 0 0 1 1 ↑ XX X X X X 0 1 ↑ XX 1 1 0 0 1 0 1 04 1 C9 DIM1 [2:0] 1 44 1 1 0 BEh 1 1 1 BFh PWM_DIV [7:0] 0F LEDONR LEDONPOL LEDPWMOPL 0 0 C0h 0 1 C1h 1 C5h VRH [5:0] 0 X 0 26 BT [2:0] 1 00 0 0 00 1 1 ↑ XX X VMH [6:0] 31 1 1 ↑ XX X VML [6:0] 3C 0 1 ↑ XX 1 1 1 ↑ XX nVM 0 1 ↑ XX 1 1 0 X X X 1 0 0 0 1 1 1 C7h 0 0 D0h VMF [6:0] 1 0 X X 0 C0 1 1 ↑ XX 1 1 ↑ XX 0 1 ↑ XX 1 1 ↑ XX KEY [23:16] 55 AA PGM_ADR [2:0] 00 PGM_DATA [7:0] 1 1 0 1 0 0 XX 0 1 D1h 1 1 ↑ XX KEY [15:8] 1 1 ↑ XX KEY [7:0] 0 1 ↑ XX 1 1 0 1 1 ↑ 1 XX X X X X 1 ↑ 1 XX X ID2_CNT [2:0] X ID1_CNT [2:0] XX 1 ↑ 1 XX BUSY VMF_CNT [2:0] X ID3_CNT [2:0] XX MULTI-INNO TECHNOLOGY CO.,LTD. 66 0 0 X X 1 0 X X D2h XX P.16 Ver 1.2 MODULE NO.: MI0283QT-11 Read ID4 0 ↑ 1 XX 1 1 0 1 0 0 1 1 D3h 1 ↑ 1 XX X X X X X X X X XX 1 ↑ 1 XX 0 0 0 0 0 0 0 0 00 1 ↑ 1 XX 1 0 0 1 0 0 1 1 93 1 ↑ 1 XX 0 1 0 0 0 0 0 1 41 0 1 ↑ XX 1 1 1 0 0 0 0 0 E0h 1 1 ↑ XX X X X X 1 1 ↑ XX X X 1 1 ↑ XX X X 1 1 ↑ XX X X X 1 1 ↑ XX X X X X X VP0 [3:0] 08 VP1 [5:0] 0E VP2 [5:0] 12 X VP4 [3:0] 05 VP6 [4:0] 03 1 1 ↑ XX X Positive Gamma 1 1 ↑ XX X Correction 1 1 ↑ XX 1 1 ↑ XX X 1 1 ↑ XX X X X 1 1 ↑ XX X X X 1 1 ↑ XX X X X 1 1 ↑ XX X X 1 1 ↑ XX X X 1 1 ↑ XX X X X X 0 1 ↑ XX 1 1 1 0 1 1 ↑ XX X X X X 1 1 ↑ XX X X VN1 [5:0] 1A 1 1 ↑ XX X X VN2 [5:0] 20 1 1 ↑ XX X X X 1 1 ↑ XX X X X X X X VP13 [3:0] 09 VP20 [6:0] 47 VP36 [3:0] VP27 [3:0] 86 VP43 [6:0] 2B X VP50 [3:0] 0B VP57 [4:0] X 04 VP59 [3:0] 00 VP61 [5:0] 00 VP62 [5:0] 00 VP63 [3:0] 0 0 0 00 1 VN0 [3:0] X 08 VN4 [3:0] 07 VN6 [4:0] 1 1 ↑ XX X Negative Gamma 1 1 ↑ XX X Correction 1 1 ↑ XX 1 1 ↑ XX X 1 1 ↑ XX X X X 1 1 ↑ XX X X X 1 1 ↑ XX X X X 1 1 ↑ XX X X VN61 [5:0] 1 1 ↑ XX X X VN62 [5:0] 1 1 ↑ XX X X X X 1 1 1 0 X 0E VN13 [3:0] 05 VN20 [6:0] VN36 [3:0] 3A VN27 [3:0] 8A VN43 [6:0] X 40 VN50 [3:0] 04 VN57 [4:0] X E1h 18 VN59 [3:0] 0F 3F 3F VN63 [3:0] 0F Digital Gamma Control 1 0 1 ↑ XX 1st Parameter 1 1 ↑ XX RCA0 [3:0] BCA0 [3:0] XX : 1 1 ↑ XX RCAx [3:0] BCAx [3:0] XX 16th Parameter 1 1 ↑ XX RCA15 [3:0] BCA15 [3:0] XX Digital Gamma Control 2 0 1 ↑ XX 1st Parameter 1 1 ↑ XX RFA0 [3:0] BFA0 [3:0] XX : 1 1 ↑ XX RFAx [3:0] BFAx [3:0] XX 64th Parameter Interface Control 1 1 1 0 0 0 1 1 ↑ XX 0 1 ↑ XX 1 1 1 1 0 1 1 ↑ XX MY_EOR MX_EOR MV_EOR X 1 1 ↑ XX X X 1 1 ↑ XX X X RFA63 [3:0] 0 1 1 0 1 BFA63 [3:0] EPF [1:0] ENDIAN 0 X 1 0 BGR_EOR X X WEMODE X X MDT [1:0] RM E3h XX 1 DM [1:0] E2h RIM F6h 01 00 00 Note 1: Undefined commands are treated as NOP (00h) command. Note 2: B0 to D9 and DE to FF are for factory use of display supplier. USER can decide if these commands are available or they are treated as NOP (00h) commands before shipping to USER. Default value is NOP (00h). Note 3: Commands 10h, 12h, 13h, 26h, 28h, 29h, 30h, 36h (Bit B4 only), 38h and 39h are updated during V-SYNC when ILI9341 is in Sleep OUT mode to avoid abnormal visual effects. During Sleep IN mode, these commands are updated immediately. Read status (09h), Read display power mode (0Ah), Read display MADCTL (0Bh), Read display pixel format (0Ch), Read display image mode (0Dh), Read display signal mode (0Eh) and Read display self diagnostic result (0Fh) of these commands are updated immediately both in Sleep IN mode and Sleep OUT mode. MULTI-INNO TECHNOLOGY CO.,LTD. P.17 MODULE NO.: MI0283QT-11 Ver 1.2  INITIAL CODE code void INIT() { write_cmd(0x01); //software reset delay(5); write_cmd(0x28); // display off //--------------------------------------------------------write_cmd(0xcf); write_data16(0x00,0x00); write_data16(0x00,0x83); write_data16(0x00,0x30); write_cmd(0xed); write_data16(0x00,0x64); write_data16(0x00,0x03); write_data16(0x00,0x12); write_data16(0x00,0x81); write_cmd(0xe8); write_data16(0x00,0x85); write_data16(0x00,0x01); write_data16(0x00,0x79); write_cmd(0xcb); write_data16(0x00,0x39); write_data16(0x00,0x2c); write_data16(0x00,0x00); write_data16(0x00,0x34); write_data16(0x00,0x02); write_cmd(0xf7); write_data16(0x00,0x20); write_cmd(0xea); write_data16(0x00,0x00); write_data16(0x00,0x00); //------------power control-----------------------------write_cmd(0xc0); //power control write_data16(0x00,0x26); write_cmd(0xc1); //power control write_data16(0x00,0x11); //--------------VCOM䆒ᅮϡヺড়ᓔᴎӮ䮾⚕ --------write_cmd(0xc5); //vcom control write_data16(0x00,0x35);//35 write_data16(0x00,0x3e);//3E write_cmd(0xc7); //vcom control write_data16(0x00,0xbe); // 0x94 //------------memory access control-----------------------write_cmd(0x36); // memory access control write_data16(0x00,0x48); //0048 my,mx,mv,ml,BGR,mh,0.0 write_cmd(0x3a); // pixel format set write_data16(0x00,0x55);//16bit /pixel //----------------- frame rate-----------------------------write_cmd(0xb1); // frame rate write_data16(0x00,0x00); write_data16(0x00,0x1B); //70 //----------------Gamma--------------------------------write_cmd(0xf2); // 3Gamma Function Disable write_data16(0x00,0x08); write_cmd(0x26); write_data16(0x00,0x01); // gamma set 4 gamma curve 01/02/04/08 MULTI-INNO TECHNOLOGY CO.,LTD. P.18 MODULE NO.: MI0283QT-11 Ver 1.2 write_cmd(0xE0); //positive gamma correction write_data16(0x00,0x1f); write_data16(0x00,0x1a); write_data16(0x00,0x18); write_data16(0x00,0x0a); write_data16(0x00,0x0f); write_data16(0x00,0x06); write_data16(0x00,0x45); write_data16(0x00,0x87); write_data16(0x00,0x32); write_data16(0x00,0x0a); write_data16(0x00,0x07); write_data16(0x00,0x02); write_data16(0x00,0x07); write_data16(0x00,0x05); write_data16(0x00,0x00); write_cmd(0xE1); //negamma correction write_data16(0x00,0x00); write_data16(0x00,0x25); write_data16(0x00,0x27); write_data16(0x00,0x05); write_data16(0x00,0x10); write_data16(0x00,0x09); write_data16(0x00,0x3a); write_data16(0x00,0x78); write_data16(0x00,0x4d); write_data16(0x00,0x05); write_data16(0x00,0x18); write_data16(0x00,0x0d); write_data16(0x00,0x38); write_data16(0x00,0x3a); write_data16(0x00,0x1f); //--------------ddram --------------------write_cmd(0x2a); // column set write_data16(0x00,0x00); write_data16(0x00,0x00); write_data16(0x00,0x00); write_data16(0x00,0xEF); write_cmd(0x2b); // page address set write_data16(0x00,0x00); write_data16(0x00,0x00); write_data16(0x00,0x01); write_data16(0x00,0x3F); // write_cmd(0x34); //write_cmd(0x35); // tearing effect off // tearing effect on //write_cmd(0xb4); // display inversion //write_data16(0x00,0x00); write_cmd(0xb7); //entry mode set write_data16(0x00,0x07); //-----------------display--------------------write_cmd(0xb6); // display function control write_data16(0x00,0x0a); write_data16(0x00,0x82); write_data16(0x00,0x27); write_data16(0x00,0x00); } write_cmd(0x11); //sleep out delay(100); write_cmd(0x29); // display on delay(100); write_cmd(0x2c); //memory write MULTI-INNO TECHNOLOGY CO.,LTD. P.19 MODULE NO.: MI0283QT-11 Ver 1.2  RELIABILITY TEST No. 1 2 3 4 5 6 7 Test Item High Temperature Storage Low Temperature Storage High Temperature Operating Low Temperature Operating Temperature Cycle Damp Proof Test Vibration Test 8 Drooping test 9 ESD test 10 Hitting test 11 Pen sliding durability test Test Condition 802/96 hours -302/96 hours 702/96 hours -202/96 hours -302~25~80210cycles 60590%RH/96 hours Frequency10Hz~55Hz~10Hz Amplitude1.5mm, XYZ direction for total 3hours (Packing condition) Drop to the ground from 1m height, one time, every side of carton. (Packing condition) Voltage:±8KV R: 330Ω Air discharge, 10time C: 150pF 1,000,000 times in the same point, Hitting pad: tip R3.75 mm,Silicone rubber, Hardness:40 deg.; Load: 2.45N; Hitting speed: Twice/sec; Electric load: None; Test area should be at 1.8 mm inside of insulation. Inspection after test Inspection after 2~4hours storage at room temperature, the sample shall be free from defects: 1.Air bubble in the LCD; 2.Sealleak; 3.Non-display; 4.missing segments; 5.Glass crack; 6.Current Idd is twice higher than initial value. 7. The surface shall be free from damage. 8.Linearity must be no more than 1.5% by the linearity tester. 9..The Electric charact eristics requirements shall be satisfied. 100, 000 times minimum Hitting pad: tip R0.8 mm Plastic pen; Load: 1.47N; Sliding speed: 60 mm/sec; Electric load: None Test area should be at 1.8 mm inside of insulation. Remark: 1.The test samples should be applied to only one test item. 2.Sample size for each test item is 5~10pcs. 3.For Damp Proof Test, Pure water(Resistance10MΩ) should be used. 4.In case of malfunction defect caused by ESD damage, if it would be recovered to normal state after resetting, it would be judge as a good part. 5.EL evaluation should be excepted from reliability test with humidity and temperature: Some defects such as black spot/blemish can happen by natural chemical reaction with humidity and Fluorescence EL has. 6.Failure Judgment Criterion: Basic Specification, Electrical Characteristic, Mechanical Characteristic, Optical Characteristic. MULTI-INNO TECHNOLOGY CO.,LTD. P.20 Ver 1.2 MODULE NO.: MI0283QT-11  INSPECTION CRITERION PAGE 1 OUTGOING QUALITY STANDARD OF 7 TITLE:FUNCTIONAL TEST & INSPECTION CRITERIA This specification is made to be used as the standard acceptance/rejection criteria for Color mobile phone LCM with touch panel. 1 Sample plan Sampling plan according to GB/T2828.1-2003/ISO 2859-11999 and ANSI/ASQC Z1.4-1993, normal level 2 and based on: Major defect: AQL 0.65 Minor defect: AQL 1.5 2. Inspection condition Viewing distance for cosmetic inspection is about 30cm with bare eyes, and under an environment of 20~40W light intensity, all directions for inspecting the sample should be within 45 against perpendicular line. 3. Definition of inspection zone in LCD. A B C Zone A: character/Digit area Zone B: viewing area except Zone A (ZoneA+ZoneB=minimum Viewing area) Zone C: Outside viewing area (invisible area after assembly in customer’s product) Fig.1 Inspection zones in an LCD. Note: As a general rule, visual defects in Zone C are permissible, when it is no trouble for quality and assembly of customer’s product. MULTI-INNO TECHNOLOGY CO.,LTD. P.21 Ver 1.2 MODULE NO.: MI0283QT-11 PAGE 2 OUTGOING QUALITY STANDARD OF 7 TITLE:FUNCTIONAL TEST & INSPECTION CRITERIA 4. Inspection standards 4.1 Major Defect Item No Items to be inspected 4.1.1 All functional defects 1) No display 2) Display abnormally 3) Missing verticalhorizontal segment 4) Short circuit 5) Back-light no lighting, flickering and abnormal lighting. 4.1.2 Missing Missing component 4.1.3 Outline dimension 4.1.4 linearity Classification of defects Inspection Standard Major Overall outline dimension beyond the drawing is not allowed. No more than 1.5% 4.2 Cosmetic Defect Item No Items to be inspected Classification of defects Inspection Standard For dark/white spot, size is defined Clear Spots Black white defect as = ( x + y) and 1. Spot Pinhole, Foreign Particle, polarizer Dirt y x 2 Zone Size(mm) Acceptable Qty A B 0.1 Ignore 0.10 0.15 2 C Minor Ignore 0.15 0.20 1 0.20 0 4.2.1 2. Zone Size(mm) Clear Spots Acceptable Qty A B 0.1 Ignore 0.10 0.15 3 C Minor TP Dirt Ignore 0.15 0.25 2 0.25 0 MULTI-INNO TECHNOLOGY CO.,LTD. P.22 Ver 1.2 MODULE NO.: MI0283QT-11 PAGE 3 OUTGOING QUALITY STANDARD OF 7 TITLE: FUNCTIONAL TEST & INSPECTION CRITERIA 3. 2. Zone Dim Spots Circle shaped and dim edged defects Acceptable Qty Size(mm) A B 0.2 Ignore 0.20 0.40 2 0.40 0.60 1 0.60 0 C Minor Ignore 4.2 Cosmetic Defect Item No Items to be inspected size(mm) Line defect Black line, White line, Foreign material on polarizer 4.2.2 Classification of defects Inspection Standard Acceptable Qty zone L(Length) W(Width) A B Ignore W 0.02 Ignore L 3.0 0.02 W 0.03 2 L 2.0 0.03 W 0.05 1 0.05 W Define as spot defect C Ignore The line can be seen after mobile phone in the operating condition: size(mm) Foreign material on TP film Minor Acceptable Qty zone L(Length) W(Width) A B Ignore W 0.03 Ignore L 5.0 0.03 W 0.05 3 0.05 W Define as spot defect C Ignore If the scratch can be seen after mobile phone cover assembling or in the operating condition, judge by the line defect of 4.2.2. If the scratch can be seen only in non-operating condition or some special angle, judge by the following. MULTI-INNO TECHNOLOGY CO.,LTD. P.23 Ver 1.2 MODULE NO.: MI0283QT-11 PAGE 4 OUTGOING QUALITY STANDARD OF 7 TITLE:FUNCTIONAL TEST & INSPECTION CRITERIA Size(mm) Dim line defect Zone L(Length) 4.2.3 Acceptable Qty W(Width) A B Polarizer scratch Ignore W 0.03 Ignore TP film scratch 5.0 L 10.0 0.03 W 0.05 2 L 5.0 0.05 W 0.08 1 0.08 W 0 C Minor Ignore Air bubbles between glass & polarizer 2. Zone Size(mm) 4.2.4 Polarize Air bubble Acceptable Qty A B 0.2 Ignore 0.20 0.30 2 0.30 0.50 1 0.50 0 C Minor Ignore 4.3. Cosmetic Defect Item No Items to be inspected Classification of defects Inspection Standard (i) Chips on corner A:LCD Glass defect Minor X Y Z 2.0 S Disregard Notes: S=contact pad length Chips on the corner of terminal shall not be allowed to extend into the ITO pad or expose perimeter seal. MULTI-INNO TECHNOLOGY CO.,LTD. P.24 Ver 1.2 MODULE NO.: MI0283QT-11 PAGE 5 OF OUTGOING QUALITY STANDARD 7 TITLE:FUNCTIONAL TEST & INSPECTION CRITERIA B:TP Glass defect X(mm) Y(mm) Z(mm) 3.0 3.0 Disregard (ii)Usual surface cracks A:LCD Glass defect X Y Z 3.0
很抱歉,暂时无法提供与“1947”相匹配的价格&库存,您可以联系我们找货
库存:47
