104110009
104110009
    SEEED(矽递科技)
    RASPBERRYPI7"TOUCHSCREENDISP
104110009 数据手册
Page 1 of 4 Raspberry Pi 7" Touchscreen Display SKU: 104110009 (images/104110009 01_01.jpg) Description The 7” Touchscreen Monitor for Raspberry Pi gives users the ability to create all-in-one, integrated projects such as tablets, infotainment systems and embedded projects. The 800 x 480 display connects via an adapter board which handles power and signal conversion. Only two connections to the Pi are required; power from the Pi’s GPIO port and a ribbon cable that connects to the DSI port present on all Raspberry Pi’s.  Touchscreen drivers with support for 10-finger touch and an on-screen keyboard will be integrated into the latest Raspbian OS for full functionality without a physical keyboard or mouse. Features: • • • • • • • 7” Touchscreen Display. Screen Dimensions: 194mm x 110mm x 20mm (including standoffs) Viewable screen size: 155mm x 86mm Screen Resolution 800 x 480 pixels 10 finger capacitive touch. Connects to the Raspberry Pi board using a ribbon cable connected to the DSI port. Adapter board is used to power the display and convert the parallel signals from the display to the serial (DSI) port on the Raspberry Pi. Part List: • • • • 1 x 7” Touchscreen Display 1 x Adapter Board 1 x DSI Ribbon cable 4 x stand-offs and screws (used to mount the adapter board and Raspberry Pi board to the back of the display • 4 x jumper wires (used to connect the power from the Adapter Board and the GPIO pins on the Pi so the 2Amp power is shared across both units) • 1 x Perspex layer frame in your choice of colour! Page 2 of 4 Page 3 of 4 Overview Page 4 of 4 (http://www.seeedstudio.com/depot/Maker-Pro-t-1672.html?ref=pinfo) Designer: Raspberry Pi Foundation (http://www.raspberrypi.org/) Other Products From This Designer (http://www.seeedstudio.com/depot/Raspberry-Pi-Foundation-m93.html?ref=pinfo) Weight: 514 g http://www.seeedstudio.com/depot/Raspberry-Pi-7-Touchscreen-Display-p-2541.html?cPa... 12/2/2015
104110009 价格&库存
很抱歉,暂时无法提供与“104110009”相匹配的价格&库存,您可以联系我们找货
