410-113
410-113
    DIGILENT(迪芝伦)
    BOARD PMODDA2 FOR DAC121S101
410-113 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodDA2™ Reference Manual Revised May 24, 2016 This manual applies to the PmodDA2 rev. B Overview The PmodDA2 is a 12-bit Digital-to-Analog converter powered by the Texas Instruments DAC121S101. As it is able to simultaneously convert two separate channels of digital information provided over an interface similar to SPI, users can easily compare the two reconstructed signals. Features include:       12-bit digital-to-analog converter Two simultaneous conversion channels Very low power consumption Small PCB size for flexible designs 1.0“ × 0.8” (2.5 cm × 2.0 cm) 6-pin Pmod connector with GPIO interface Library and example code available in resource center The PmodDA2. 1 Functional Description The PmodDA2 provides two channels of 12-bit Digital-to-Analog conversion, allowing users to achieve a resolution up to about 1mV. 2 Interfacing with the Pmod The PmodDA2 communicates with the host board via an SPI-like protocol. By bringing the Chip Select line to a low voltage state, users may send a series of 16 clock pulses on the Serial Clock line (SCLK). The data is sent out with the most significant bit (MSB) first on the last 12 clock pulses. An example data stream of how the data might look is provided from the TI datasheet below: DOC#: 502-113 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 2 PmodDA2™ Reference Manual Figure 1. PmodDA2 data stream. Pin 1 2 3 4 5 6 Signal ~SYNC DINA DINB SCLK GND VCC Description Chip Select Data In for Channel A Data In for Channel B Serial Clock Power Supply Ground Power Supply (3.3V/5V) Table 1. PmodDA2 pinout table. Figure 2. PmodDA2 circuit diagram. Any external power applied to the PmodDA2 must be within 2.7V and 5.5V; however, it is recommended that Pmod is operated at 3.3V. 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1 inch long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 2
410-113 价格&库存
很抱歉,暂时无法提供与“410-113”相匹配的价格&库存,您可以联系我们找货
