410-245
410-245
    DIGILENT(迪芝伦)
    AD5628 12 Bit Digital to Analog Converter (DAC) Evaluation Board
410-245 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com PmodDA4™ Reference Manual Revised May 24, 2016 This manual applies to the PmodDA4 rev. B Overview The Digilent PmodDA4 is an octal, 12-bit digital-to-analog converter module. Features include:          Eight channel, 12-bit DAC Capable of eight simultaneous outputs High-speed DSP compatible Power-down function capability Low power consumption Small PCB size for flexible designs 1.2“ × 0.8” (3.0 cm × 2.0 cm) 6-pin Pmod connector with SPI interface Follows Digilent Interface Specification Type 2 Example code available in resource center The PmodDA4. 1 Functional Description The PmodDA4 utilizes Analog Devices AD5628 to provide a signal DAC capable of 8 simultaneous output channels. With its internal reference voltage of 2.5V, a resolution of approximately 1 mV can be achieved. 2 Interfacing with the Pmod The PmodDA4 communicates with the host board via the SPI protocol. By driving the Chip Select (CS) line to a logic level low voltage, users may send a series of 32 bits of information with the data clocked into the appropriate register on the falling edge of the Serial Clock (SCLK). Once the 32nd bit of information has been clocked in, the command that was sent in the data stream is executed. An example data stream of how the 32 bits are to be sent to the module is provided below from the AD5628 datasheet. DOC#: 502-245 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 3 PmodDA4™ Reference Manual DB31 (MSB) X X Command Bits X X C3 C2 C1 Address Bits C0 A3 A2 A1 A0 Data Bits D11 D10 D9 D8 D7 D6 D5 D4 D3 D2 D1 D0 DB0 (LSB) X X X X X X X X Table 1. Example data stream from the AD5628 datasheet. Users should note that the PmodDA4 by default attempts to use an external reference voltage. However, as there is no external reference voltage provided on the Pmod, users must write to the register to program the chip to use its internal reference voltage of 2.5V. The data stream required to change this is provided below: Internal REF Register (DB0) Action 0 1 Reference off (default) Reference on Table 2. Internal reference register from the AD5628 datasheet (table 10). DB31 to DB28 DB27 DB26 DB25 DB24 X 1 0 0 0 Don't Cares DB23 X Command bits (C3 to C0) DB22 X DB21 X DB20 X Address bits (A3 to A0) - don't cares DB19 to DB1 X DB0 1/0 Don't cares Internal REF register Table 3. 32-bit input shift register contents for reference set-up command from the AD5628 datasheet (table 11). The various commands and addresses available for the on-board AD5628 can be found on page 22 of its datasheet. 2.1 Pinout Description Table Pin Signal Description 1 ~CS Chip Select 2 MOSI Master-Out-Slave-In 3 (NC) Not Connected 4 SCLK Serial Clock 5 GND Power Supply Ground 6 VCC Power Supply (3.3V/5V) Any external power applied to the PmodDA4 must be within 2.7V and 5.5V; however, it is recommended that Pmod is operated at 3.3V. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 3 PmodDA4™ Reference Manual 3 Physical Dimensions The pins on the pin header are spaced 100 mil apart. The PCB is 1.2 inches long on the sides parallel to the pins on the pin header and 0.8 inches long on the sides perpendicular to the pin header. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 3
410-245
物料型号:PmodDA4
器件简介:PmodDA4是Digilent公司生产的一个八通道、12位数字到模拟转换器模块。它具有以下特点: - 8个通道,12位DAC,能够同时输出8个信号 - 高速DSP兼容 - 具有掉电功能 - 低功耗 - 小型PCB尺寸,便于灵活设计 - 6针Pmod连接器,带有SPI接口 - 遵循Digilent接口规范类型2 - 在资源中心提供示例代码
引脚分配:PmodDA4的6针Pmod连接器的引脚分配如下: - 1号引脚:~CS(芯片选择) - 2号引脚:MOSI(主设备输出从设备输入) - 3号引脚:NC(未连接) - 4号引脚:SCLK(串行时钟) - 5号引脚:GND(电源地) - 6号引脚:VCC(电源供电,3.3V/5V)
参数特性:PmodDA4使用Analog Devices公司的AD5628芯片,具有内部参考电压2.5V,可实现大约1mV的分辨率。
功能详解:PmodDA4通过SPI协议与主机板通信。通过将芯片选择(CS)线驱动到逻辑低电平,用户可以发送一系列32位信息,数据在串行时钟(SCLK)的下降沿被时钟进入相应的寄存器。当第32位信息被时钟进入后,发送的数据流中的命令被执行。
应用信息:PmodDA4可以用于需要数字信号转换为模拟信号的各种应用,如信号发生器、音频处理等。
410-245 价格&库存
很抱歉,暂时无法提供与“410-245”相匹配的价格&库存,您可以联系我们找货
