Page 1 of 1
SparkFun Breadboard Power Supply Stick 5V/3.3V
PRT-13 032 ROH S
images are CC BY-NC-SA 3.0
Description: This is a very simple board that takes a 6-12V input voltage and outputs
a selectable 5V or 3.3V regulated voltage. All headers are 0.1" pitch for simple
insertion into a breadboard.
Input power can be supplied to either the DC barrel jack or the two pin header labeled
+ and -. Output power is supplied to the pins labeled GND and VCC. Board has both
an On/Off switch and a voltage select switch (3.3V/5V).
The two sets of four GND and VCC holes are spaced such that when connected to
our Basic Breadboard both power busses will be powered.
Note: Headers are not supplied. You will need to supply your own headers to connect
this board to a breadboard. Check below for some breakaway header strips.
Dimensions: 2.15x0.65"
Features:
6-12V input voltage via barrel jack or 2-pin header
3.3V or 5V regulated output voltage
800mA Operating Current
ON/OFF switch
Output voltage select switch
Power status LED
PTC fuse protected power
5.5x2.1mm center positive barrel jack
https://www.sparkfun.com/products/13032
4/16/2015
很抱歉,暂时无法提供与“PRT-13032”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+91.595801+11.84460
