Page 1 of 3
BOARDS / BREAKOUT BOARDS
Stereo 2.8W Class D Audio Amplifier TS2012
PRODUCT ID: 1552
Page 2 of 3
DESCRIPTION
This incredibly small stereo amplifier is surprisingly powerful - able to deliver 2 x
2.8W channels into 4 ohm impedance speakers (@ 10% THD). Inside the miniature
chip is a class D controller, able to run from 2.7V-5.5VDC. Since the amp is a class
D, it's incredibly efficient (89% efficient when driving an 8Ω speaker at 1.5 Watt) making it perfect for portable and battery-powered projects. It has built in thermal
and over-current protection but we could barely tell it got hot. This board is a
welcome upgrade to basic "LM386" amps!
The inputs of the amplifier go through 1.0uF capacitors, so they are fully
'differential' - if you don't have differential outputs, simply tie the R- and L- to
ground. The outputs are "Bridge Tied" - that means they connect directly to the
outputs, no connection to ground. The output is a ~300KHz square wave PWM that
is then 'averaged out' by the speaker coil - the high frequencies are not heard. All
the above means that you can't connect the output into another amplifier, it should
drive the speakers directly.
Comes with a fully assembled and tested breakout board with 1.0uF input
capacitors. We also include a dual mini DIP switch for setting the amplifier gain on
the fly, 3.5mm screw-terminal blocks so you can easily attach/detach your
speakers, and some header in case you want to plug it into a breadboard. You will
be ready to rock in 15 minutes! Speakers are not included, use any 4 ohm or 8 ohm
impedance speakers.
• Output Power: 2.8W at 4Ω, 10% THD, 1.7W at 8Ω, 10% THD, with 5V Supply
• PSRR: 70 dB typ @ 217 Hz with 6 dB gain
• Designed for use without an output filter, when wires are kept at under 2"-4"
long
• Four pin-selectable gains: 6dB, 12dB, 18dB and 24dB. Select with the onboard
switches or by setting the G0 and G1 breakout pins (see schematic for breakout
board showing gain pin settings for details)
• Excellent click-and-pop suppression
Page 3 of 3
• Thermal shutdown protection
• Independent channel shutdown
• Low current draw: 5mA quiescent and 2uA in shutdown mode
http://www.adafruit.com/products/1552
7/21/2015
很抱歉,暂时无法提供与“1552”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+94.789201+12.25882
