DFR0119
DFR0119
    DFROBOT
    3WMINIAUDIOSTEREOAMPLIFIER
DFR0119 数据手册
    3W mini audio stereo amplifier (SKU:DFR0119)   Contents    1 Introduction 2 Specifications 3 Connection Diagram Introduction This is a mini stereo amplifier. It is a fully functional, two-channel audio amplifier, comes with electric switcher. Specifications      Power Supply: DC 3.6-5.5V (DO NOT apply over 5.5V, it damage the chip presently) Output power: 3w+3w (4 ohms) Efficiency: >90% Size: 15.5*24mm Weight: 7g Connection Diagram Sleep Mode: When the "SW" PIN is low(0V), it will turn off the amplifier's bias circuitry. and enter the sleeping mode. When the "SW" value is high(5V), it will enter the working mode. By default (without anything connected to this PIN) it will be HIGH / powered on and in normal operation. If you don't need to turn it off manually, you can leave this pin disconnected like in the wiring diagram picture. This feature is optional and will allow you by software to turn it off, to avoid noise or save power. Note, the picture has a battery for power input, but you can use other power supply at 5V.       Powered By DFRobot © 2008-2017
DFR0119
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一种光隔离型集成电路,用于检测和测量转速、频率、脉冲等信号。
3. 引脚分配:EL817有8个引脚,包括电源、输出、输入和地。
4. 参数特性:工作电压范围为3.5V至24V,输出电流为50mA,响应频率为500kHz。
5. 功能详解:EL817通过光电耦合实现信号隔离,提高系统的抗干扰能力。
6. 应用信息:EL817广泛应用于工业自动化、医疗设备等领域。
7. 封装信息:EL817采用DIP-8封装。
DFR0119 价格&库存
很抱歉,暂时无法提供与“DFR0119”相匹配的价格&库存,您可以联系我们找货
DFR0119
  • 1+49.336511+6.39580
库存:13
